Monster MotorsportVolks Autos
Results 1 to 15 of 15
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    Worcestershire
    2,794
    What should I be boosting at Stage 2 Shark?
    Im seeing 1.2 bar across the rev range(constant), until very late 6k rpm, here it does a quick peak to 1.5 bar.
    I thought I read some where that it should be 1.5bar constant?
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,420
    If I remember(and I may well be wrong on this),the K04 is pretty much at it's limts trying to hold 1.5bar constantly,and if you consider that a GT3071 won't go much over 2bar,you can see why.
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,794
    If this link works.
    Dyno results.
    Stage 2 Dyno S3 photo by mjr901 | Photobucket
    (No DSG map)
    RedDejavu's Avatar
    Feb 2011
    Bracknell
    1,485
    you should be pushing at least 300ft from stage 2. Something seems to holds it back? Mine was doing simmilar with stage 1 + intake and exhaust accordingly to the graph
    Be patient. English is tough.
    Now:
    61 Audi S3 BE S-Tronic Ibis White: Build Thread.
    / Black Edition pack (SatNav, Bluetooth) / Parking Sensors / Tinted windows / piano inlays and finish / Cruise Control / Interior light pack /
    /Mods: REVO Stage 2+: Revo Intake / BCS Powervalve TBE system / LOBA HPFP / Crystal Clear H11 FOGS / Black roof + spoiler vinyl wrap / H&R Anti-roll bars / Superpro ALK /
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,794
    Cars showing no faults either and runs well so it's either an intake issue or mapping I should think.
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,794
    Why would my torque reading be quite low? I haven't had DSG map but still think it should be higher.
    Essentially my torque figures at stage 2 match yours at Revo stage 1!
    + I'm 15bhp off stage 1 Revo at stage 2 shark level.
    hmmmmmm not good at all....
    RedDejavu's Avatar
    Feb 2011
    Bracknell
    1,485
    but you do have stage 2 shark with dsg fix to overwrite torque limiter dont you? it could be map/intake or dyno lottery yet values are way off tbh.
    Now:
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,794
    Yes I have the updated shark patch map which got rid of the pause after each gear change.
    Was your stage 1 map "generic" or was it logged etc and done properly?
    My shark map was simply uploaded in about 8 mins and I was on my way. no custom tweaks etc.
    RedDejavu's Avatar
    Feb 2011
    Bracknell
    1,485
    with my revo stage 1 was only uploaded and that was it no rolling road nor did they do any tweaking, with stage 2 AMD guys did all tweaking and tbh now car feels much more refined and somehow smoother yet punchier.
    Now:
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    901
    I've just thought as well from looking at the two plots, mjr yours is at the wheel but Red yours isn't stated. Could the difference just be power at the wheels versus power at the flywheel?
    Daytona Grey A4 3.0 TDi Quattro S-Tronic Black Edition
    RedDejavu's Avatar
    Feb 2011
    Bracknell
    1,485
    Quote Originally Posted by Daggerit View Post
    this is very possible Daggerit! Mine is clearly at the flywheel reading from the power figures.
    Now:
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,794
    Just had the car dyno'd again with the twintercooler.
    now 337bhp, 295 p/ft.
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,794
    Dyno + Forge Twintercooler Development for the facelift 8P's.
    linky---> Stage 2 dyno S3 + forge development twintercooler. photo by mjr901 | Photobucket
    you might have to scroll through the pictures to find new results.
    Acheron's Avatar
    Jan 2012
    South Africa
    263
    Quote Originally Posted by mjr901 View Post
    Too many variables, mate. It could be pulling back on the boost due to timing pull, fuel rail pressures, etc. Remember you're only seeing what the car is achieving in terms of boost, not what the map is asking for.
    You need to get a good WOT 4th gear run logged on the road to get a useful set of data (particularly requested vs actual boost/fuel pressures and timing) to plot/compare along a rev range.
    Current: 2010 Audi S3 Sportback S-tronic
    Ex: 2007 Audi A3 Sportback - 2.0T DSG
    Ex: 2008 Opel Corsa OPC
    Ex: 2004 Opel Corsa Lite
    Ex: 1978 VW Beetle
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,794
    Quote Originally Posted by Acheron View Post
    yep I'm gonna log results when I get my car back if I can pinch the machine from a local mate.
    Getting withdrawal symptoms now, been almost 2 weeks @ forge!
  1. Stock and remap boost pressures...what should they be?
    By g10chy in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th January 2011, 18:56
  2. what should an a3 1.8t be boosting at?
    By tyson in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st August 2010, 10:52
  3. What should my standard apy s3 boost to?????
    By malcolm30029085 in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th January 2010, 01:23
  4. What should I ask for my S3 ?
    By batty in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th February 2004, 09:46
  5. What should I do???
    By Steve_C_NWales in forum General Chat
    Last Post: 11th April 2003, 22:24
