Volks AutosChris Nott
Results 1 to 11 of 11
    Sep 2012
    37
    rear parking sensors?
    i think my parking sensors have a fault?, when i start the car from cold and stick it in reverse i get a continuous beep, but after runnning the car and putting it in reverse i get no continuous beeps? i tried scanning with vcds and get no faults, so i tried to scan the part assist module and it says not found?
    so how do i scan for faults on the parking sensors?
    26,776
    Depending on the year, module 76 is parking on older 8P's & module 10 on newer facelifts, try either direct & see what happens.
    _G_
    _G_'s Avatar
    Jul 2011
    869
    I don't think it is a fault. On my one when I stick it in reverse I do get the continuous beep for a second or two (seems like longer) but then it settles down to normal operation. So for example, if I was sat on the drive and put it into reverse I would get the continuous sound for a bit. If I drove forward and the reversed onto the drive it would be normal.
    Have you tried cleaning the sensors? Give them a good wash and see if that helps. This time of year with all the road salt and muck caked on it can severely limit the detection range.
    26,776
    Depends how long the beeps are for, I need to check tbh if there's an adaptation for this beep duration.
    Sep 2012
    37
    Quote Originally Posted by _G_ View Post
    hmm maybe it is normal then? i have tried cleaning the sensors, but to be honest it has been the same since i had the car i got it second hand so i don't know what i should be hearing?
    but i get the same as you start up from cold continos beep for what seems like 10 seconds, then it stops the sensors work when i reverse off my drive, then when the engine is warm i get one beep when i stick it in reverse?
    very strange mine is a 57 tfsi quattro
    26,776
    10 seconds is way to long & indicates a fault, so could be the cold is affecting the sensor system & initially thinking its a fault.
    Sep 2012
    37
    it's been doing it since i've had it, back in july so can't be the cold
    if i do a full vagcom scan would it show up? or do i need to scan the module for the sensors?
    26,776
    Well if it works even when long beep, then should be ok for now, but when it does long beep, test each sensor by standing in front of them, also check in the module itself & check readings when standing in front of them.
    Sep 2012
    37
    just scanned module 76 park assist and it says no response from controller?
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 47 52 56 62 72
    VIN: WAUZZZ8P27A214962 Mileage: 138970km/86351miles
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    22-AWD -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Address 01: Engine Labels: 06F-907-115-AXX.lbl
    Part No SW: 8P0 907 115 K HW: 8P0 907 115 B
    Component: 2.0l R4/4V TFSI 0040
    Revision: 5BH16--- Serial number: AUX7Z0G3FNP0AJ
    Coding: 01030003180F0060
    Shop #: WSC 00024 000 00000
    VCID: 3A55EE9E758A8FC82F8
    No fault code found.
    Readiness: 0000 0000
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.lbl
    Part No SW: 1K0 907 379 AB HW: 1K0 907 379 AB
    Component: ESP 4MOTION MK60 0102
    Revision: 00H13001
    Coding: 0021122
    Shop #: WSC 06314 000 00000
    VCID: 72C506BE6D7A3788278
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 AC HW: 8P0 820 043 AC
    Component: KlimavollautomatH19 0360
    Revision: 130321 Serial number: 8P0820043AC
    Shop #: WSC 00000 000 00000
    VCID: 6DFF15C27444E870FAA
    Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
    Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
    Component: Bordnetz-SG H43 1201
    Revision: 00H43000 Serial number: 00000007023621
    Coding: E18C5F01B014100000160000160000000008FE175C0100
    Shop #: WSC 06314 000 08192
    VCID: 40A19C761356D51861C
    Subsystem 1 - Part No: 8P2 955 119 E Labels: 1KX-955-119.CLB
    Component: Wischer AU350 H01 0130
    Coding: 00062736
    Shop #: WSC 06314
    Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
    Component: REGENLICHTSENSORH13 0090
    Coding: 00150573
    Shop #: WSC 06314
    Address 15: Airbags Labels: 8P0-959-655-94.lbl
    Part No SW: 8P0 959 655 C HW: 8P0 959 655 C
    Component: Airbag 9.41 H13 4260
    Revision: 91H13426 Serial number: 003620G45A47
    Coding: 0071612
    VCID: 42A5967E1D5AC708778
    Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
    Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
    Component: J0527 H36 0070
    Coding: 0002012
    VCID: 41A79972185CDC106E2
    Part No: XXXXXXXXXXX
    Component: E0221 H07 0090
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
    Part No SW: 8P0 920 981 G HW: 8P0 920 981 G
    Component: KOMBIINSTR. VDO H20 0570
    Revision: D0H20004 Serial number: 2243G004006358
    Coding: 0005418
    Shop #: WSC 00581 210 64475
    VCID: 3C59E8867FBEB1F83D4
    Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
    Part No SW: 1K0 907 530 K HW: 1K0 907 951
    Component: J533__Gateway H12 0170
    Revision: H12 Serial number: 330010741301B6
    Coding: BD3F034207002103
    VCID: 2F43CFCABEC85A60886
    Address 22: AWD Labels: 1K0-907-554.lbl
    Part No: 1K0 907 554 L
    Component: Haldex 4Motion 0116
    Coding: 0000001
    VCID: 364DFAAE41926BA8CB0
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Revision: D0H20004 Serial number: AUX7Z0G3FNP0AJ
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN2.lbl
    Part No: 8P0 959 801 H
    Component: Tuer-SG 020 0090
    Coding: 0000688
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K2 909 144 L
    Component: EPS_ZFLS Kl.079 H07 1806
    Shop #: WSC 02069 000 90108
    VCID: 354FFDA25C9460B0C2A
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433 F
    Component: KSG H08 0070
    Coding: 9980202002186D098505489FC637
    VCID: 3FA39F8A6EA8AAE0186
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Part No: 1K0 907 719 C
    Component: Neigungssensor 005 0003
    Part No: 8P0 951 177
    Component: Innenraumueberw.H04 0020
    Address 47: Sound System Labels: 8Px-035-382.lbl
    Part No SW: 8P4 035 382 HW: 8P4 035 382
    Component: AB2 SUBWOOFERBOXH04 0180
    Revision: 00003 Serial number: 30674702867448
    VCID: F1C789B2E87C8C905E2
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN2.lbl
    Part No: 8P0 959 802 H
    Coding: 0000688
    Address 56: Radio Labels: 8J0-035-1xx-56.clb
    Part No SW: 8P0 035 186 S HW: 8P0 035 186 S
    Component: R Concert2+ H03 0280
    Revision: 00H03000 Serial number: AUZ1Z3K6048403
    Coding: 0000000
    1 Fault Found:
    01042 - Control Module; Not Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 5
    Fault Frequency: 1
    Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
    Part No: 8P4 959 801 D
    Component: Tuer-SG 020 0070
    Coding: 0000144
    Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
    Part No: 8P4 959 802 D
    Coding: 0000144
    26,776
    Well I would check for any water in the rear drivers quarter incase its got wet & affected the wiring, the fact it beeps when its in reverse means its getting a signal from the cars systems via canbus to make it beep, but this maybe why its giving the faulty long beep.
    Sep 2012
    37
    ok thanks i will have a look
  1. Something is up with my rear parking sensors???
    By dickys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th July 2005, 16:32
  2. Anybody got rear parking sensors?
    By VAGMAN1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th March 2005, 11:26
  3. Retro-fit rear parking sensors
    Last Post: 11th February 2005, 23:47
  4. Aftermarket Rear Parking Sensors
    By hfu in forum Detailing
    Last Post: 15th April 2004, 14:15
  5. Aftermarket Rear Parking Sensors
    By hfu in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th March 2004, 13:02
