Chris NottBadger5
Results 1 to 32 of 32
Thread: Boot Light LED
    A3Kent's Avatar
    Different Gear
    May 2012
    1,065
    Boot Light LED
    I've just received all the relavant interior LED's from Trups and the only LED that I can't get to work is the boot one.
    I've obviously asked Trups the question via a PM but was hoping to get this sorted tonight as I hate things not working!
    Anyway, i've tried a couple of his different LED modules and neither work and I've bent the module they set into this way and that and no luck!
    Could something like a fuse knock it out? Nothing else is out it would seem.
    09 Audi A3 2.0 TDI 170 S-Line SB 8P3
    - Full Leather - LED DRL's - BOSE - Cruise Control - RNS-E Mk2 - AMI - Bluetooth - Folding Mirrors -
    VCDS owner - A3 Grille Install Guide
    Cruiser89's Avatar
    Advanced In Car Technologies
    Bournemouth, Dorset
    1,425
    Follow Cruiser89 On Twitter Add Cruiser89 on Facebook Visit Cruiser89's Youtube Channel Visit Cruiser89's Instagram Channel
    Make sure the contacts on the plastic plug in bit are actually touching the metal prongs. Trups LEDs are good but do feel that the metal contacts could be a bit thicker / wider and the solder isn't that strong (constructive crytisicm).
    Failing that, whack a multimeter and check you are getting a supply. If not then you have a fuse out somewhere. If you have a supply try re-jiggling the led. You can also do a continuity check across the LED board on both + and -
    Tim - Project & Marketing Manager of Advanced In-Car Technologies LTD. An Audi Approved OEM / Retrofit Specialist Company. All views expressed are my own and bear no reflection on Advanced In Car Tech.
    Audi A3 For Sale: 2011 Audi A3 1.8TFSI Black Edition. Low Mileage. Great Condition. Manuf Warranty
    http://www.audi-sport.net/vb/sale-wanted-audi-cars/219560-sale-2011-audi-a3-1-8tfsi-black-edition-low-mileage-great-condition-manuf-warranty.html
    Nov 2012
    21
    Have you shut your boot locked the car and unlocked it to see if that does any think? if i leave my boot open to long the light seems to time out and goes off untill i shut the boot and reopen the car again.
    Jameze's Avatar
    James
    Jul 2011
    Leeds
    525
    Boot Light LED
    Have you tried unplugging the light unit itself and swapping it for one of the other interior lights that you know for sure works?
    A3Kent's Avatar
    Different Gear
    May 2012
    1,065
    Right, i'm still not up and running but i'm getting there. As Jameze suggested I swapped a footwell light with the boot one and it works so it must be the LED module. Try another LED module I think
    A3Kent's Avatar
    Different Gear
    May 2012
    1,065
    On close inspection of the plastic module the LED fits into it looks like i've bent the metal connector sections so much that they've snapped away from the body on one side! That'll teach me for trying to get it to work in the freekin' dark.
    So...a new plastic boot light module (assume it's the same as the footwell lights?) is needed unless I can repair this one. Any idea how much one is and a part number?
    Fossie
    Rhubarb Triangle
    3,969
    Quote Originally Posted by A3Kent View Post
    Silly question but as LED's only work one way round have you tried to connect the other way round ?
    coxy8329's Avatar
    Nov 2011
    Hampshire
    166
    I had a similar problem, was a loose connection in the light housing. Cut the panel connector off and soldered the wires directly to the pins.
    Make sure it's connected the right way round.
    EM Tuning VAG Panel LED fitting guide..
    Audi A3 Sline 170 2.0 TDI
    Mods Done
    RNS-E mkII fitted, Tinted Repeaters, Center Armrest,
    LED Interior Lights, Cruise Control, LED Number Plate Lights,
    VW fan windshield washers, S3 Pedals, Metal Footrest,
    DPF & EGR delete, Unicorn Remap, De-badged the tailgate.
    With DPF Without DPF
    A3Kent's Avatar
    Different Gear
    May 2012
    1,065
    Good idea coxy. I may end up doing that.
    SPARTAN91's Avatar
    RED FIVE STANDING BY
    Zookeeper Champion
    Nov 2012
    NORFOLK
    411
    Lightbulb
    I had the same problem at the weekend with my boot leds not working.The 2 I bought both work in the glove box but neither work in the boot but the oem lights are fine so I still working on the problem.Also the ones I have will only fit in one way as they match the oem light fitting.
    Cruiser89's Avatar
    Bournemouth, Dorset
    1,425
    I expect Trups will get back to you...
    He is a very busy chap and his LEDs are pretty popular. When I did my A3 a year ago and had a problem he rang me and sorted the issue!
    A3Kent's Avatar
    Different Gear
    May 2012
    1,065
    Quote Originally Posted by coxy8329 View Post
    All fixed! As coxy suggested above, i've soldered the wires direct to the pins on the light module so will avoid paying for another module. I may end up doing the footwells like this as well to stop any connection issues I may get but hopefully i'll be ok.
    The LED bulbs all work a treat so can recommend getting Trups to give you a price to kit out your interior lighting. I wasn't sure about it to start with but I must confess that they are nice and bright and I think it brings the interior up to date. I did the footwells, front and rear ceiling lights (including map lights), vanity lights, glove box light and boot light.
    Thanks all for your help.
    Jun 2011
    Wellingborough
    1,169
    Quote Originally Posted by SPARTAN91 View Post
    Where did you buy them from? My boot LED is the only solution so far that works in the 8P boot.
    Trups
    SLOW REPLIES BETWEEN 22nd - 30th June due to been out the office, please bare with me. Thanks
    Bi Xenon Projector kits starting at £79.99 per pair.
    EM Tuning Lighting.
    Feb 2011
    Plymouth
    1,135
    how much is a kit for a 3 dr 8P?
    Acheron's Avatar
    Jan 2012
    South Africa
    263
    Bought a set of these a while back: AUDI A3 S4 RS3 8L 8P 8V A1 8X Cabrio LED SMD Footwell Glovebox Luggage Light 019 | eBay
    Stuck one in the boot and the other in the glovebox. Both work flawlessly
    Current: 2010 Audi S3 Sportback S-tronic
    Ex: 2007 Audi A3 Sportback - 2.0T DSG
    Ex: 2008 Opel Corsa OPC
    Ex: 2004 Opel Corsa Lite
    Ex: 1978 VW Beetle
    A3Kent's Avatar
    Different Gear
    May 2012
    1,065
    Quote Originally Posted by Acheron View Post
    Bit pricey those.
    Trups' bulbs work in your existing OEM light modules so no need for more modules. I guess thats why they are charging more.
    Jun 2011
    Wellingborough
    1,169
    if you had to buy 4 pairs of these on a 5dr car for the boot, glove, front footwells and 4 puddles that would get pricey. you can buy my whole 5dr kit for cars with light pack for £59 posted to the uk or NI.
    Trups
    EM Tuning Lighting.
    Jun 2011
    Wellingborough
    1,169
    Quote Originally Posted by smurfworth View Post
    Hi.
    does it have a light pack?
    what year is the car?
    Trups
    EM Tuning Lighting.
    Feb 2011
    Plymouth
    1,135
    Light pack would include footwell lights?
    Its a 2006
    SPARTAN91's Avatar
    Zookeeper Champion
    Nov 2012
    NORFOLK
    411
    Got them on ebay from Ireland like I said these work ok in glove box but no joy in boot here's some pics lights 001.jpg lights 002.jpg AY58 003.jpg In the first pic oem light on top led spec bottom
    Jun 2011
    Wellingborough
    1,169
    My boot light is £7 and £1.85 postage and will go nicely into the OEM light and will work.
    the only thing i can think is sell that spare lamp onto someone and buy the one i have.
    EM Tuning Lighting.
    Jun 2011
    Wellingborough
    1,169
    Its a 2006
    This thread has the info you need for the pricing for the Kits. - Audi LED upgrade package
    Trups
    EM Tuning Lighting.
    Fossie
    Rhubarb Triangle
    3,969
    Quote Originally Posted by t8ups View Post
    Trups
    Where mate ?
    Sorry - ignore that - it's in your footer and I was looking for a 'purple' hyperlink !!!!
    Acheron's Avatar
    Jan 2012
    South Africa
    263
    Trups
    Not debating the fact that yours are cheaper, only the claim that yours are the only solution that works
    Ex: 1978 VW Beetle
    Fossie
    Rhubarb Triangle
    3,969
    Lots of things are different in South Africa. Mainly the friggin weather !!!
    Acheron's Avatar
    Jan 2012
    South Africa
    263
    So, second post in a row that you've referenced my country of origin as being relevant somehow without actually commenting on what I've actually written. Feel free to share with the class why you think the fact that I'm South African has ANYTHING at all to do with either my opinion or the technical aspects of my post.
    Ex: 1978 VW Beetle
  28. #27
    Fossie
    Rhubarb Triangle
    3,969
  29. #28
    Jun 2011
    Wellingborough
    1,169
    The ones you linked are from ireland, the ones SPRATAN91 got are from ireland, what are the chances they could be the same seller or supplier? seems like it could be a hit and miss with them.?
    EM Tuning Lighting.
  30. #29
    The Governor's Avatar
    Mar 2012
    Southampton
    436
    Holy thread resurrection :D
    The boot light on my 8P3 is ultra dim and useless, are the LED ones like unleashing the righteous light of the lord in the boot?
  31. #30
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,382
    i have 2 lights (one on either side) in the boot and and its very nice and lit up... can see everything!
    A3 Sportback 2.0TDI
    Dark Headlining, Bose, Alcantara Leather, Interior Lights Pack
    MODS:
    S3 facelift,
    RS3 Grill, 19" RS6, TTRS FBMFSW, A5 S-Line Heated Seats, Bi-Xenons, Auto Lights & Wipers, Eibach Sportlines, Auto Folding & Dimming Dumbo Mirrors, S3 brakes, US Centre Console, Cruise, Pioneer HU, Reverse Camera, OEM Parking Sensors, LED Tail Lights, S3 Pedals, Tints, Carbon Trims.
  32. #31
    Mar 2012
    Southampton
    436
    I don't want to be doing no rewiring though fella, was looking for a straight swap, my car only has one light in it...
  33. #32
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,382
    in that case just change to the led bulb... still better than the crappy normal ones
    A3 Sportback 2.0TDI
    MODS:
    S3 facelift,
  1. how to fit a boot light LED ?
    By rOb_A in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th June 2012, 13:44
  2. Help with the boot light
    By natedog in forum RS6 Forum
    Last Post: 6th October 2006, 11:03
  3. boot light
    By imported_migzy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th January 2006, 11:43
  4. Faulty glovebox/boot lights
    By koonl in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd April 2004, 17:20
  5. S3 Boot light switch
    By Mike.M in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st January 2004, 10:28
