Sky InsuranceAH Fabrications
Results 1 to 14 of 14
    Mar 2010
    Somewhere
    323
    Any problem with switching??
    Hi all,
    Just wondering if there is any problem if I fill the car with normal petrol again because I have been using momentum for few months now at the moment I have got half of tank of momentum.
    Thank you for your comment
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    Worcestershire
    2,785
    I doubt you'll even notice....
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    Mar 2010
    Somewhere
    323
    just dont want to mess anything up
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,785
    Stay away from the supermarket fuel unless its premium grade, otherwise if you just want normal unleaded use BP or the like as theirs is still more refined and contain additives to protect your engine.
    Supermaket fuel is 'raw' fuel. (unless high octane)
    Mar 2010
    Somewhere
    323
    tesco I am using now any problem you reckon with this ??
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,785
    Tesco momentum is fine mate, I worked for a premium brand petrol company for 3+ years and have been told many stories about fuel.
    Now I'm in the motor trade working for LandRover and the stories about budget supermarket fuel keep on rolling in. literally.
    Any high octane from anywhere = fine
    Use BP,Shell, Esso, Texaco or the like for normal unleaded if there is nothing else as there are additives put in.
    Mar 2010
    Somewhere
    323
    unfortunately the nearest petrol station is tesco so I am just thinking if i switch from momentum back to normal is there going to be an issue or not ??
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,785
    Personally, I wouldn't touch it.
    However, many people use standard super market fuel with no problems.
    Some cars misfire all day on the stuff.
    + Knowing my luck I'll get a clogged injector or fuel filter if I used it.
    Mar 2010
    Somewhere
    323
    I guess to start of with audi use normal fuel on the s3 but I decided not to once I have got it / now I guess it will be fine don't you think if I went back to normal tesco unleaded?
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,785
    you'll be fine *touch wood*.
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,300
    Quote Originally Posted by mjr901 View Post
    Personally, I wouldn't touch it. However, many people use standard super market fuel with no problems.Some cars misfire all day on the stuff. + Knowing my luck I'll get a clogged injector or fuel filter if I used it.
    The ony time I've ever had problems was persistent misfires on Asda 95RON fuel when the good stuff was hard to get locally....before having the car remapped.
    If your car is mapped,then you'd be well advised to stick to either V-Power or Momentum,but otherwise,decent quality branded petrol should be fine.
    Mar 2010
    Somewhere
    323
    Quote Originally Posted by S3Alex View Post
    car is not mapped, when I got the car I decided to try out momentum but now I am wondering if there is going to be any issue if I fill the car up with normal unleaded from tesco but with half of tank of momentum still in the car
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,300
    Quote Originally Posted by I oOEddOo I View Post
    I don't think you'll have any problems there at all......as I said,I only had problems with using what I could buy locally,when a better quality premium fuel would have been the ideal choice.
    Mar 2010
    Somewhere
    323
    Good will giv it a try later this week when I re fuel with normal unleaded from hlf of tank of momentum
  1. Replies: 5
    Last Post: 25th July 2012, 21:11
  2. any problems with a4 cabs 2006
    By bearder2006 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 11th April 2010, 21:48
  3. Any help with my horn problem please?
    By sulaiman in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th November 2009, 22:41
  4. Problems with Boost - Any ideas?
    By Gavin Cooper in forum Tuning
    Last Post: 31st December 2007, 09:42
  5. Niggly problems with HCB-30 & K750 - any ideas
    By technics100 in forum In-Car Entertainment
    Last Post: 23rd January 2006, 17:09
