    May 2012
    Carlisle
    311
    Wheel balance weights
    Hi
    Hi just wondering if anyone knows if you buy the genuine/ factory fit stick on wheel balance weights. I need my first 2 tyres and would to use the Audi weights. Reason being on my last car I was changing weights all the time because they were corroding an looked awfull.
    cheers
    27,121
    You're referring to the balancing weights put on by tyre companies, never once had a corrosion issue, just take it to a good tyre place to be done as they all use stick on ones & then its balanced properly & can be tested by the machine for accuracy.
  1. Judder At Speed - Not wheel Balance
    By Fast3000 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 8th April 2009, 13:20
  2. Steering Wheel Wobble at High Speed (Wheels Balanced)
    By jomnhta in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd January 2009, 14:02
  3. Balance weight glue
    By smokeymike in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 29th February 2008, 17:30
  4. Stock s3 wheel/tier weight
    By nadir in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th August 2007, 09:58
  5. Wheel Balancing
    By Smudge973 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 18th July 2007, 12:55
