Results 1 to 28 of 28
Like Tree1Likes
  • 1 Post By 347
Thread: Rnse advice please ( pics inside )
    nally's Avatar
    MPG the new BPH
    May 2010
    Liverpool
    2,102
    Thumbs up Rnse advice please ( pics inside )
    Hello asn
    i have audi convert think its number 2 see pic
    I am thinking of replacing with this unit
    RNS E Audi A3 S3 Navigation Media Chrome Satnav DVD 2012 Map | eBay
    is this the correct unit for my car ?
    will my bury kit work with this ?
    will my aux plug in still work?
    will the stearing wheel controls have more function? ( only volume one the right works not functions )
    is this unit worth it ?
    Is the nav software any good ?
    here is the aux port and the left hand side controls on the stearing wheel
    thanks as always nally
    2009 (58) plate audi A3 Sline 2.0TDI, DRL's with washers, Half Leather / Alcantara, I Pod Aux, 15% tints / EM tuning L.E.D. interior upgrade, fully machine corrected!
    27,121
    Yes thats an A3 version.
    Your problem is the antenna system for radio is different for the rns-e so you may get degraded reception.
    To fix this there is a mod for antenna amps, looms, extension cables etc to fit which gets rid of any errors & gives you optimal reception.
    As long as the bury kit has the approperiate connections, which going by the fact you have the concert 2+, then should be ok if fitted/coded correctly.
    Auxin will work, but only when its been coded & rewired to a new connector for rns-e as not same as the concert.
    The controls will stay the same, as in volume up/down, the left selector dial will flick the stations, tracks etc, mode only works when bt is fitted, so effectively should be the same unless you want bt aswell, with a minor addition of the nav directions repeated when pressing left scroll button in when on a route.
    IMHO ist the best unit to fit as it works with everything else flawlessly & oem look imho cant be beaten.
    I use nav software everyday & for me its perfectly good enough & I goto different locations daily in all areas without any hiccups thus far.
    You could also consider installing the sds variant of which I can supply/fit, I can make sure all your concerns above are taken care of & you're not far from me next week tbh mate, will be in salford for a few days if interested, send me a PM if interested
    nally's Avatar
    MPG the new BPH
    May 2010
    Liverpool
    2,102
    Thanks for the info it's never easy with audi is it!
    just don't wanna shell out that sort of money then it will not work with aux and having to cut lumes up its nuts.
    Ideally I thought it was plug and play would work with
    aux
    bury
    steering controls
    sat nav
    & all other bits straight out the box but I know I need Bluetooth if I want my phone to work with it and its about and extra £100
    nally's Avatar
    MPG the new BPH
    May 2010
    Liverpool
    2,102
    Oh by SDS veriant what is this ? Diff unit / diff software and what would be the benefit / different
    27,121
    The work is all factory when finished, no looms are cut up as such mate & the audi bt is not an extra £100 I'm afraid or are you referring to an additional bt addon to the bury being £100?
    27,121
    SDS speech dialogue system, basically voice control of certain functions, like nav, phone, radio, cd.
    Yes sds specific mk2 unit.
    2,180
    I would avoild that seller, had a very bad dealing with him, just glad I never laid our any money with him. ended up getting one from this seller worked out cheaper as well. AUDI A3 S3 RS3 RNS-E SAT NAV MMI WITH LED LCD NEWEST MINT | eBay
    gary3306's Avatar
    Oct 2010
    Northumberland
    950
    Lee, I used that guy for my unit. He's very good to deal with. For some reason, it wouldn't allow my paypal payment to go through as it said I couldn't use that payment method for that item. I contacted him and said it sounded a bit dodgy and I wanted to leave it. He said, send me your address, I'll send you the unit BEFORE YOU PAY ANYTHING, and if you're happy, send me the money as a gift with paypal. How many sellers would do that?
    A4 S-Line. Mods so far; Cruise, DIS, Mk2 RNS-e, Audi 6 CD changer, XcarLink with self manufactured permanent ipod dock, B8 MFSW, Dectane Dayline Headlights with independantly switched DRL's, RS4 Rear ARB, De-badged, RS4 pedals, HIDS, RS4 front grille and RS4 style fog surrounds, LCR splitter in Satin Black, Rear Park Assist, LED gearknob, Red footwell lighting, Kitchen sink and Shower cubicle.
    s3facelift09's Avatar
    Dec 2012
    124
    Quote Originally Posted by nally View Post
    aux
    bury
    steering controls
    sat nav
    It pretty much is all plug&play, the steering controls will work without additional coding, the radio reception is satisfactory, for sat nav, you could buy a gps antenna cheap on ebay and install it somewhere inside the car..
    27,121
    Quote Originally Posted by s3facelift09 View Post
    the radio reception is satisfactory.
    It all comes down to where you use the radio, some are not satisfactory at all & you end up with static, if you're constantly in a city, then its probably fine, but I can assure you most of my clients who experience this, within 5 minutes say, swap it out, as even once hearing the radio like this. annoys them.
    So he should be made aware of the pifalls beforehand of such upgrades, as allot of installers dont say squat until after its been fitted, leaving the client in a situation where the units fitted already & no choice but to stay as is or the additional cost.
    Dec 2012
    124
    I wish I live somewhere near you, beacuse I retrofitted a Lithuaninan RNS-e in my S3, and I'm satisfied with the reception but if I had an expert like you I would definitely like it to be perfect and that is connected with the antenna in the rear window, and that you do all the necessary coding so there aren't any faults/errors when connected to VCDS.. :/
    Yesterday I even had a slight problem with my RNS-e but this is for another thread, it goes beyond this subject..
    2,180
    Quote Originally Posted by gary3306 View Post
    I also remember your unit had the smashed connectors on the back and a faulty GPS antenna, I just saying I've had bad dealing with him and don't trust when he gets his units from, but that can go for all sellers.
    Dec 2011
    MIDLANDS
    256
    i had my RNSE from the first seller. i went to his house paid cash and he did the install and coding at the same time. im more than happy with mine, and ive been in touch with him since to ask about BT to which he answered my questions.
    A3 2.0TDI S LINE, Awesome remapped, ITG, Milltek, S3 Front + Rear bumpers + Sideskirts, Cruise and slammed on coilovers. NO SMOKE - NO POKE!!!!!
    gary3306's Avatar
    Oct 2010
    Northumberland
    950
    Quote Originally Posted by B5NUT View Post
    No Lee, I got my unit off the guy you linked to; viliusk2006
    nally's Avatar
    MPG the new BPH
    May 2010
    Liverpool
    2,102
    I mean the bt as blue tooth add on I thought this was around the £100 mark
    nally's Avatar
    MPG the new BPH
    May 2010
    Liverpool
    2,102
    thats quite cool how much would you expect to pay for one like that ?
    nally's Avatar
    MPG the new BPH
    May 2010
    Liverpool
    2,102
    Quote Originally Posted by WALTO TDI View Post
    where are the units from that what am interested in stolen ?
    nally's Avatar
    MPG the new BPH
    May 2010
    Liverpool
    2,102
    i worked in halfrauds many moons ago and when we used to upgrade vw / audi raidos ppl did complain about signal so we fitted signal boosters ( by auto leads ) and it was a little metal thing that looked like a male connection for radio but was spliced in to the permanent live. Is this the same sort of thing. ?
    27,121
    No offence gazza, but I wouldnt do this & only person who would offer this imho, is someone who loses nothing if you dont pay, in other words it cost them nothing in the 1st place or very very little, sounds rather dodgy doesnt it.
    The audi system isnt that cheap, but it integrates well with the other systems.
    PM & I'll advise.
    Nothing like that mate, its the proper audi system fitted as per factory to make rns fully compatible with antenna system.
    nally's Avatar
    MPG the new BPH
    May 2010
    Liverpool
    2,102
    Pm sent
    347
    347's Avatar
    Sep 2006
    253
    be careful doing this , sending as a gift removes the pay pal protection , if there is a problem with purchase pay pal will not return your money as it was a gift not a transaction .
    nally likes this.
    2010 2.0 Tfsi BE ibis white DSG , now sharked
    nally's Avatar
    MPG the new BPH
    May 2010
    Liverpool
    2,102
    Quote Originally Posted by 347 View Post
    so basically if its just so they don't pay the charge ( purchase one) you could just offer to pay more ? If they say no steer clear ?
    nally's Avatar
    MPG the new BPH
    May 2010
    Liverpool
    2,102
    Defo dodgy IMO
    asked him on two messages to confirm where the units are from and each time just sends me a mobile nnumber
    if he can't answer that then its getting swerved.
    not having anyone's solen goods you get enough of that sterio type being a scouser.
    2,180
    O very much so! he will not answer his mobile either, he will only respond to some txt messages would avoid like the plague.
    nally's Avatar
    MPG the new BPH
    May 2010
    Liverpool
    2,102
    Would hate the thought it was out if someone's pride and joy. You would prob have a broken window in 6 months after delivery
    would never have it sent out to me
    27,121
    Thats the issue, they sell you a unit & potentially it could go missing later, also after 45 days the paypal claim period is over, so if a fault arises after this, warranty could be obsolete, as some of my clients found out, so you're goosed.
  28. #27
    nally's Avatar
    MPG the new BPH
    May 2010
    Liverpool
    2,102
    pmed you mate if you can help ?
  29. #28
    Dec 2011
    MIDLANDS
    256
    I think they are imported from the EU
  1. Calling S3 Seat Experts - Movement Problem with Pics, Advice Please?
    By fran-s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th April 2012, 21:11
  2. Opinions please - Pics inside!
    By The Engineer in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th May 2011, 00:31
  3. A few paint defects (PICS) Advice Please
    By Westy in forum Detailing
    Last Post: 18th June 2009, 12:07
  4. ARB Bushes (Pics inside) + Advice needed...
    By CLS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th June 2007, 23:02
  5. Your thoughts please.... Pics inside....
    By imported_tobycruse in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th February 2006, 14:44
