Sky InsuranceChris Nott
Results 1 to 8 of 8
Thread: Mfsw retrofit
    Jan 2013
    Denmark
    Mfsw retrofit
    Hi I have an 8p from 2008 and want to upgrade my 4 spoke sterring wheel for a 3 spoke mutil function steerig wheel that I found on ebay. Both are with the square airbag cover and I thourght that thevairbag module would fit. However the airbag cover is naturally a little bit different on the 3 spoke compared to the 4 spoke.
    Is it possible to replace just the airbag cover or do I need a complete new airbag?
    Fossie
    Rhubarb Triangle
    3,969
    Quote Originally Posted by heole03 View Post
    Can you post pics of the back of both please together with a pic of the wheel you want to fit.
    You need to upload to photobucket or similar first and then post the image file ( if you didn't already know ! ).
    Edit : don't forget to identify which is which !!!
    27,114
    If you can find a cover its a maybe, but you need to compare airbag bases to be 100% sure, iirc when I checked, I noticed the 4 spoke I had to research, was different shape to the 3, so didnt continue researching as wasnt worthwhile.
    Jan 2013
    Denmark
    Thanks for the replies. I have used a couple of hours searching for a cover for the 3-spoke without luck. Guess there is no way out of buying a new airbag
    27,114
    I have a complete dsg mfsw for sale with airbag if of help.
    Dec 2011
    MIDLANDS
    253
    Can you take the paddles off the DSG wheel so that it serves just as a standard MFSW? does yours have the silver buttons? and how much do you want for it?
    A3 2.0TDI S LINE, Awesome remapped, ITG, Milltek, S3 Front + Rear bumpers + Sideskirts, Cruise and slammed on coilovers. NO SMOKE - NO POKE!!!!!
    gary3306's Avatar
    Oct 2010
    Northumberland
    950
    The paddles can be removed. I have a B8 A4 DSG MFSW on my A4, but I just left them on. They don't hinder anything, I never notice they're there now, and when I put the car back to standard and put the standard MFSW back on, the DSG wheel can still be sold as such.
    A4 S-Line. Mods so far; Cruise, DIS, Mk2 RNS-e, Audi 6 CD changer, XcarLink with self manufactured permanent ipod dock, B8 MFSW, Dectane Dayline Headlights with independantly switched DRL's, RS4 Rear ARB, De-badged, RS4 pedals, HIDS, RS4 front grille and RS4 style fog surrounds, LCR splitter in Satin Black, Rear Park Assist, LED gearknob, Red footwell lighting, Kitchen sink and Shower cubicle.
    27,114
    Exactly, the paddles are so minimal anyway, they dont get in the way & you can only see the tops very minimally I wouldnt bother removing thm, as it would leave a hole at rear, but that cant be seen tbh as its hidden behind the cluster.
    Nope mines not silver buttons, just red/white stitching iirc.
  1. MFSW retrofit
    By latta1989 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th February 2010, 17:23
  2. MFSW retrofit- apologies in advance!
    By ~RS~ in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th May 2009, 13:06
  3. MFSW retrofit
    By jwhat in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 11th February 2009, 20:32
  4. B6 OEM MFSW Retrofit
    By JohnboyC in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th September 2008, 12:11
  5. mfsw retrofit
    By quattrov6tdi in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th November 2007, 00:36
Tags for this Thread
