Sky InsuranceVolks Autos
    Mar 2011
    A3 8P spare wheel part number
    I bought my second hand car with a non-audi spare wheel but it doesn't allow the boot liner to fully sit flat. Can somebody tell me what the part number or size that is should be for the 18 inch spare in a 2006 hatchback? I have seen 5x100 1J0601027M advertised but not entirely sure this would fit. Thanks!
    Fossie
    Rhubarb Triangle
    3,969
    5K0 601 011 - 3.5J - 5X112 - £260 including tyre from Audi !!!
    Part number used to be 1K0 601 011
    That wheel you referred to was used on the A3 8L and TT but is still used on the A1. Don't know if the wheel well is the same size as yours though !
    27,099
    You could simply ad some lengths of wood bonded to the underside of the boot trim to raise it slightly, job done
    shariain's Avatar
    May 2004
    Glasgow
    1,173
    Space saver size for A3
    Stud pattern 5 holes 112pcd
    Offset ET 25.5
    Size 3 1/2j x 18H2
    Part number 1K0601027B
    I have the same problem as the OP the garage I got my car from gave me a spare wheel from a A4 everything is the same apart from the offset but it still fits the car ok apart from the boot carpet doesn't fit down the way it should.
    S3 1.8t Ming blue with ivory leather & 18"tt alloys
  1. Difference in RS4(RSTT) wheel part numbers?
    By Danman1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd February 2012, 13:28
  2. wheel part number
    By tdi-man in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th July 2011, 13:52
  3. Audi alloy wheel part number
    By Mr Singh in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st May 2010, 18:20
  4. any one got a spare battery cover or part number for a 2.0 tdi?
    By scottie123 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th January 2009, 17:22
  5. Help! Audi Steering Wheel Part Number
    By roosterboy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th May 2005, 10:10
