EM TuningJMB Retrofits
    Jan 2013
    Hesitation when revs hit 2800+ - A3/8P 170 Sportback 57 plate TDi Manual
    Hey guys, I'd like a bit off info before I take my car to the garage. Just recently I have been having this problem where when I hit 2800+ revs under accelaration my car hesitates (badly). I have just had the injectors done under the recall and hoped it would cure it but it hasn't.. Sometimes it can be fine all day, then the next day its the same old problem..
    Its got 50k on the clock
    Any info would be good please..
    Chris
    27,097
    Check fuel filter mate 1st, if its black as your hat, swap it out, maybe even fuel pump under rear seat, if continues then need to do some vcds logs of engine at these revs.
    Jan 2013
    Just a note to say thanks. Just done a fuel filter change and did the oil and filter too. Its spot on now..
    cheers !
    Jan 2012
    SW London
    794
    Was gonna suggest using some vpower or bp ultimate too. I know its more expensive but its worth it
  1. Hesitation when cold.
    By Andy in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th November 2013, 22:01
  2. Engine hesitates when cold?
    By g10chy in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th May 2010, 15:20
  3. HELP!! Problem with slight hesitation when coming off idle
    By Mattfaced in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th January 2010, 18:32
  4. Hesitation when pressing accelerator
    By Beef in forum A2 forum
    Last Post: 6th October 2008, 08:06
  5. Hesitation through revs
    By imported_Robbyc in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th July 2006, 17:16
