Volks AutosEM Tuning
    Jan 2013
    audi s3 mild ticking noise at idle and when pulling away fast paced
    got a ticking noise when cars idling had car since 8000k now at 40k had gearbox replaced under warranty at 22k and exhaust manifold and cat gasket think that was the way i drove it when i got it treat her nicer now tho although im not sure wether the ticking noise is a hole in exhaust maybe when they replaced gearbox they had to take exhaust off and dealership obv dont use exhaust paste to ensure combustion so the ticking could actually be blowing from a pipe unsure tho any help appreciated
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    933
    When your car is stationary and you put the cabin lights on are they blinking or just behave normally?
    I really struggled to read your post.
    VCDS USER
    Jan 2013
    no they behave normally
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    683
    Ticking noises are fairly common on high performance cars after a bit of a blast, its just the exhaust system cooling down & nothing to worry about.
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted!
    Bits for sale...
    Genuine S-line 18" alloys, A3 Sportback rear lights. A3 5dr window switches & mirror switch. , Brand new PD170 engine cover. PM for details.
    Jan 2013
    thanks sailo
  1. In need of URGENT HELP!!!! Power steering, and ticking noises....
    By Quattro-izy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th August 2010, 10:49
  2. Strange Noise when pulling away ?
    By Dave DND in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th January 2009, 00:20
  3. clutch noise when pulling away
    By simon-s3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th February 2008, 18:13
  4. Strange noise when pulling away..
    By Rich in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd March 2007, 18:13
  5. S3 ticking noise at idle
    By Mike.M in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th November 2003, 21:30
