Chris NottBadger5
Results 1 to 9 of 9
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,973
    cambelt change due soon........came across this.............2.0 TDI................
    Im due getting the cambelt (BKD) changed next month,and was worried when i came across people who after having the belts changed ended up worse off because apparantly the bolt for the tensioner can snap off,if its been overtightened previously,even if you put a new one in.
    Some 7-8 people (after doing a google search) had new cambelt kits fitted and around 900+miles later,the bolt sheared off ! these have been told that if the cars already had a cambelt previously and the mechanic has not torqued it to spec and overtightened it even slightly the chances are quite high of it shearing off causing serious engine damage,even if you replace it and tighten the new one to spec.........anyone had the issue? (BKD)
    Also my cambelt was replace by audi dealer on 18 january 2008 at 79,888 BKD cambelt is 75,000 miles or 5 years whichever comes first,my cars done around 43k on the belt,but next week the 5 years is up,even thoug its not done the miles,can i push it on for a little bit longer say another 2-months,or will it not last?
    Full leather/19"wheels/cruise/
    Aug 2012
    68
    Well if you get a main dealer to fit the cambelt, if it snaps they will be paying the bill! So I wouldn't worry about it! I'm a tech for vw and we've only had 1 come back with a snapper tensioner since I've been there (2 years). And it was fixed FOC! So I wouldn't worry about it!
    vw754's Avatar
    Nov 2006
    U.K
    1,973
    thanks,im getting it fitted job done for parts + labour at £90 so alot cheaper than dealer,audi dealers did the belt before so is it still worth getting a new bolt or do they come with the kit?,providing a new bolt is torqued to 20nm +45 degrees i should boe ok....touch wood.lol
    Quote Originally Posted by deanshaw24 View Post
    Aug 2012
    68
    You will want a new tensioner and nut! Yeah 20nm and 45 degrees!!
    Lewis583's Avatar
    Mar 2010
    872
    When I did the belt on my mates Seat Leon 2.0TDi 140 the kit came with everything, tensioner/stud/nut and idler/bolt, belt.
    It's not hard to wind the stud out the head so well worth doing. I would get the water pump changed too while it's in bits.
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    vw754's Avatar
    Nov 2006
    U.K
    1,973
    i wll be (always have) getting a genuine kit and w/pump from audi
    Quote Originally Posted by Lewis583 View Post
    vw754's Avatar
    Nov 2006
    U.K
    1,973
    sorry to bring up the old post.......the tensioner stud was replaced,hand tightened,then nipped tight with some mole grips,mechanic said it will be ok,because when tensioner nut gets tightened it also keeps the stud pulled tight ?..........make sense?
    how do you guys normaly fit the stud? oh and ive heard they break off never loosen off,and only break off if the tensioner nut is not torqued?
    Quote Originally Posted by vw754 View Post
    Dec 2012
    237
    so he hasn't torqued it correctly??
    the reason he said it'll be ok is for two reasons, firstly, he clearly isn't offering any sort of warranty on his work, and secondly, as it isn't his car, he just doesn't care
    vw754's Avatar
    Nov 2006
    U.K
    1,973
    what is the torque setting?
    Quote Originally Posted by T8DPR View Post
  1. Cambelt Change... When is it due on my 1.9tdi A4 Avant?
    By col004 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 6th March 2011, 21:45
  2. Audi Dealer Cambelt Change Price - Is this right?
    By bentleyboy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th November 2009, 16:56
  3. cambelt change due 4 years old?
    By dgannon69 in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd September 2006, 15:47
  4. 2001 210BHP S3 cambelt change
    By Mehdi20v in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th November 2004, 09:20
  5. Cambelt Change?
    By imported_stuartkern in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th September 2004, 14:56
