Volks AutosChris Nott
Results 1 to 11 of 11
    ilim's Avatar
    Nov 2011
    632
    Cool Keyless Start up
    has anyone installed a keyless start up system on any 8P2's. Was thinking the kit from the RS4 might work, if coding and installation was done professionally. Im sure there is a few Geniuses on here that would know the answer to this?
    Ilim
    Cruiser89's Avatar
    Advanced In Car Technologies
    Bournemouth, Dorset
    1,426
    Follow Cruiser89 On Twitter Add Cruiser89 on Facebook Visit Cruiser89's Youtube Channel Visit Cruiser89's Instagram Channel
    This site has been around a while...
    audiretrofit-rs4startbutton - Audi Retrofit
    Think you still have to have the key in the ignition to be able to use the start button...
    Tim - Project & Marketing Manager of Advanced In-Car Technologies LTD. An Audi Approved OEM / Retrofit Specialist Company. All views expressed are my own and bear no reflection on Advanced In Car Tech.
    Audi A3 For Sale: 2011 Audi A3 1.8TFSI Black Edition. Low Mileage. Great Condition. Manuf Warranty
    http://www.audi-sport.net/vb/sale-wanted-audi-cars/219560-sale-2011-audi-a3-1-8tfsi-black-edition-low-mileage-great-condition-manuf-warranty.html
    ARH
    Dec 2012
    117
    If you have to have the key in the ignition whats the point in fitting it, just turn the key a couple of times and start it yourself and save yourself £££.
    Oct 2010
    69
    I had just installed the start button, you would indeed still need to have the key in the ignition. However, if you would have keyless entry you could press the start button without using your key.
    I think the full set the install the button is about 100€, have to check that. (Have mine for sale now.) Other then that it's just nice looking. It was worth it to me!
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,536
    easy to install the rs4 start button
    but as above you still need the key in
    looks good tho
    bez101's Avatar
    Jul 2008
    8,536
    amar06fbr's Avatar
    Vorsprung Durch Technik
    Apr 2010
    West Yorkshire
    1,033
    Quote Originally Posted by denraf View Post
    when you have your car started, what if you turn press the button by accident would it turn over the starter motor?
    For Sale
    climate control (double din non chrome)
    Black roof lining (sportback)
    pm me for more info..
    BBM: 28E07323
    My Panoramic RetroFit
    bez101's Avatar
    Jul 2008
    8,536
    Quote Originally Posted by amar06fbr View Post
    if its wired up right it would turn the engine off like mine did
    or it would do nothing
    all depends on who wires it in
    27,129
    It was my original mod that Quinlivan documented.
    It is rather a copoff for audi in the RS4 tbh, as still needs key in & turned, but not started, I only installed as had it left from my S4 B6 I didnt fit, so tested on A3.
    It will not trigger starter again as once car is started, it disables that side of things even on the key aswell, it connects to the starting circuit, just a simple PTT button that signals a relay to starter.
    Bez the RS4 never turned the engine of aswell afaik mate, so how did you wire yours in if I may ask, unless you added some relays etc to reverse the wiring when car started, to kill the power, but then again the key would still be in the ignition switched position.
    bez101's Avatar
    Jul 2008
    8,536
    a sparky i know wired relays in think 3 but yeah keys still in there
    the link i posted my mate has got that fitted to his S4 and its good hes got the full kit no keys at all took him days to fit it and get it working 100%
    bez101's Avatar
    Jul 2008
    8,536
    i know on the a3 theres no relays needed
    but 1 relay is needed on the a4 or it burns the button out
    i followd the a4 fitting guide 1st on my a4 and ****ed the button
    thats when i got the sparky to fit
  1. Replies: 5
    Last Post: 19th July 2012, 20:28
  2. NOT STARTING ON THE BUTTON AND BRAKE JUDDER
    By fraz in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th July 2003, 10:45
  3. A squeeky start.....
    By dans3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th April 2003, 23:34
  4. The war has started...
    By amoffat in forum General Chat
    Last Post: 24th March 2003, 12:24
  5. Won't start!!
    By ray_nsm in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st March 2003, 00:25
