Volks AutosChris Nott
Results 1 to 18 of 18
    PaulAr's Avatar
    S3 (8P)
    Mar 2008
    Tyne & Wear
    4,047
    Milltek TBE Fitting - S3 SB MY12
    As title, how specialist a job is this.?
    Does it just need a ramp, spanners, and common sense?
    Is it a Kwit-Fit type of job, or should I look for some one that has done it before (not easy)?
    Paul
    Now:
    -MK2 Golf Gti 16V/VR6, Oak Green, Shrick, Intake, Decat, Kish Retrim, Lenso BSX..
    -BMW 335d Xdrive, Estoril Blue, fully loaded.
    Before:
    S3 (8P), Ibis, DSG, Milltek, SHARK
    BMW 320d M Sport
    S3 (8P), Sprint, REVO, H&R Springs, BBS CHs,
    Golf MK5 GTi 20TFSI - REVO Stage1, Red.
    Golf MK5 GTi 20TFSI - Std, Shadow Blue
    Civic Type `R`
    Golf MK4 GTi 18T - 200bhp, MTM ECU, Forge DV
    Golf MK3 VR6 - Cat Back
    Corrado VR6 - JAMEX
    Corrado G60 - JAMEX, BRM Charger rebuild
    etc....
    DJ-S3's Avatar
    Apr 2009
    Wakefield
    683
    Down pipe part is the tricky part, but if you've got a ramp and all the correct tools, should only take an hour or hour and a half. I'm not a mechanic but I could do it with the correct tools and a ramp in that time. It's finding someone to let you use the ramp that's the problem.
    PaulAr's Avatar
    S3 (8P)
    Mar 2008
    Tyne & Wear
    4,047
    Quote Originally Posted by DJ-S3 View Post
    Cheers.
    Tempting to use a fast fit centre then.
    Its due to be delivered on Friday so I will be itching to get it fitted on Sat!
    Paul
    Now:
    Before:
    BMW 320d M Sport
    Civic Type `R`
    Corrado VR6 - JAMEX
    etc....
    RedDejavu's Avatar
    Feb 2011
    Bracknell
    1,470
    I reckon any place that deals with exhausts will be able to do it, I only took mine down to AMD Essex as mine needed triming and welding being for 5dr and mine is 3dr otherwise I would use friend of mine for this job.
    Be patient. English is tough.
    Now:
    61 Audi S3 BE S-Tronic Ibis White: Build Thread.
    / Black Edition pack (SatNav, Bluetooth) / Parking Sensors / Tinted windows / piano inlays and finish / Cruise Control / Interior light pack /
    /Mods: REVO Stage 2+: Revo Intake / BCS Powervalve TBE system / LOBA HPFP / Crystal Clear H11 FOGS / Black roof + spoiler vinyl wrap / H&R Anti-roll bars / Superpro ALK /
    PaulAr's Avatar
    S3 (8P)
    Mar 2008
    Tyne & Wear
    4,047
    Quote Originally Posted by RedDejavu View Post
    Does the exhaust swap throw any error codes?
    cheers
    Paul
    Now:
    Before:
    BMW 320d M Sport
    Civic Type `R`
    Corrado VR6 - JAMEX
    etc....
    RedDejavu's Avatar
    Feb 2011
    Bracknell
    1,470
    I went straight stage 2 map so that was avoided.
    Now:
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    Worcestershire
    2,786
    You need to undo the prop - 3 bolts, push it to one side, you don't need the whole thing off.
    To access these bolts, spin a wheel around so the shaft rotates.
    Apart from that it bolts onto the turbo with some immensely tight nuts(bit like a nylock but with metal)
    Then it's just the hangers and normal clamps.
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    RedDejavu's Avatar
    Feb 2011
    Bracknell
    1,470
    Just dont let someone to rip you off as this is an easy fit.
    Now:
    DJ-S3's Avatar
    Apr 2009
    Wakefield
    683
    I took mine to a local garage and they quoted me 4hours, 200quid. As you can guess I told them where to go and did it with a friend at his garage.
    PaulAr's Avatar
    S3 (8P)
    Mar 2008
    Tyne & Wear
    4,047
    Had 2 quotes around £100 from specialists.
    Seems reasonable for peace of mind I guess.
    So will I have a error code after fitment then?
    I wont be getting Stage 2 flash until a CAI is fitted which may be a couple of weeks.
    Paul
    Now:
    Before:
    BMW 320d M Sport
    Civic Type `R`
    Corrado VR6 - JAMEX
    etc....
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,786
    Quote Originally Posted by PaulAr View Post
    Paul
    Mine was done for £100, actually thought it was a bit steep, but the bolts onto the turbo can be an arse.
    As for the light, It will come and go as it pleases for the time being until you map it out.
    It will not affect the car at all. no limp mode, purely just a light to annoy you.
    RedDejavu's Avatar
    Feb 2011
    Bracknell
    1,470
    mine was 3h but that included welding and triming the cat back so reasonable for my thinking.
    Now:
    PaulAr's Avatar
    S3 (8P)
    Mar 2008
    Tyne & Wear
    4,047
    Quote Originally Posted by mjr901 View Post
    Might have access to some ramps at the weekend and a hand from a guy how has some skills but tools.
    Do I need any gaskets, assembly paste etc.?
    Do the Turbo bolts require any special tools or is it just a socket and extension?
    And do these bolts need any loctite or similar compounds?
    Thanks you please
    Paul
    Now:
    Before:
    BMW 320d M Sport
    Civic Type `R`
    Corrado VR6 - JAMEX
    etc....
    DJ-S3's Avatar
    Apr 2009
    Wakefield
    683
    Gasket for the downpipe. Best to get one as it may not be able to put the old one back on. Plus there only cheap!
    someone else will help you with the other questions.
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,786
    Thanks you please
    Paul
    Hi temp exhaust paste to link any pipes together and clamp on top.
    I can't fully remember the bolts used on the diff but I think it's a female torx looking one.
    Youll see 2 when you get the car up, then spin front wheel and the prop will spin and allow easy access to the other. then push to one side, which gives you just enough room to riggle the down pipe in/out/through.
    If you want to be anal, loctite the diff bolts, but there's no real need. just do'em up tight.
    its actually very straight forward, however, the bolts on the the turbo feel like they are about as long as your arm.....as each turn is like the first.
    Air tools are your friend here.
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,786
    In regards to the gasket, use the one from your current system. brand fire new, nothing wrong with it, I did.
    PaulAr's Avatar
    S3 (8P)
    Mar 2008
    Tyne & Wear
    4,047
    its actually very straight forward, however, the bolts on the the turbo are about as long as your arm.....and each turn is like the first.
    Perfect.
    Cheers mate.
    Paul
    Now:
    Before:
    BMW 320d M Sport
    Civic Type `R`
    Corrado VR6 - JAMEX
    etc....
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,786
    Edit**
    the bolts feel as long as your arm, but they're not. just difficult to turn, or mine were anyway. the thread isn't actually that long.
