Badger5Sky Insurance
    Jul 2012
    Isle Of Man
    51
    S3 facelift 8p exhaust help
    Hi all now the exhaust
    first time owning a car with a valve in it ?? If I want to upgrade for a better sound how do i do this ?? Ie can I de cat
    Can I change back box and leave out the valve in the end which opens at 3200rpm ??
    Please help us
    thank you
    Jan 2012
    472
    You can remove the pre-cat material (nearest the turbo) without any MOT or CEL worries - it will give you 5-10hp and the turbo spools up better.
    The valve needs to be locked open - did mine a while ago and it certainly improved things (both sound and pickup).
    br20vt's Avatar
    Sep 2010
    Middlesbrough
    141
    You could go for a catback system which would get rid of the valve, or like nluk100 said lock the valve open. Its a 10 minute job and might liven things up for you
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    the valve is only pressure operated i believe so no issues with changing system completely if you wanted to leave it out
    2007 S3 PhantomSchwartz
    Spec | Auto Lights | Black Headlining | RNS-E with 6 CD Changer | Phone Prep | Facelift Tails | MFSW | Cruise | Bluetooth | Adaptive Bi-xenon Headlights |
    Mods
    | MY10 Facelift | 75% LED's | Sepang Bronze Facelift Alloys
    Plans | LED 3dr tails | BBK Setup | Some BBS | Custom TBE |
    Quote Originally Posted by N8
    Yes, but they are OEM Phaeton Helios alloy wheels, not cheap ****e aftermarket piles of poop.
    Jul 2012
    Isle Of Man
    51
    how do you lock this valve ?? and i take it, you remove the cat, get a drill, or a piece of wood hamer and destroy the insides
  1. exhaust help!!!...
    By a4quat in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th September 2007, 17:42
  2. pre/facelift s3 interior help
    By rub a dub in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th September 2007, 21:21
  3. exhaust help
    By Ibzzzzz in forum Tuning
    Last Post: 28th April 2007, 10:36
  4. New exhaust help
    By rodenal in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd December 2006, 13:53
  5. Exhaust Help!!!!
    By simondavidr in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th April 2004, 17:55
