JMB RetrofitsChris Nott
Thread: clutch issues
    Nov 2011
    14
    clutch issues
    hi all,
    i recently had problem with my clutch when putting its down it stay down and dosent go into gear. i had it towed to the mechanic and says that the hydraulics need changing and hes gonna order the part tomorrow ....my question is does anyone know where the hydraulic is. if its in the gearbox then he says it will be very expensive to fix..out of the gearbox and not very expensive any help would be greatly appreciated as money is extremely tight and i dont want this guy pulling a fast one thankssssss
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    745
    clutch issues
    You have a cylinder connected to the pedal, the pipe going from this cylinder to the gearbox where there is a clutch release bearing which is also part of the hydraulic clutch system. Hopefully it's only the pipe or pedal cylinder as if its the release bearing you may as well do the clutch while you're in there.
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted... Still....
    Boon's Avatar
    Sep 2012
    South East Kent
    427
    Change the brake & clutch fluid first, or aleast try bleeding the clutch. Could be as simple as that
    Nov 2011
    14
    thanks for the help guys...just got back from the stealership and turns out that it wasnt that serious just needed to bleed the clutch
    Graham89's Avatar
    Derv Perv
    Jul 2011
    Chelmsford, Essex
    310
    clutch issues
    Slave cinder is probably letting by. It's situated in the box I believe so it's a box out job. Whilst your there you might aswell change the clutch. Whilst that's off you have to change the dual mass flywheel. The slave cylinder is probably only about £50 but the labour added on top with the parts my bill came to £1200. I had to have this done about 18 months ago.
  1. clutch issue
    By S90GAV in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd November 2008, 17:00
  2. Please helpme with Clutch issue on -04 1.8TQ 190
    By rs_t in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st April 2008, 22:08
  3. Clutch Issue
    By iambaz in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th November 2007, 12:41
  4. s3 clutch issues
    By S3Matt1983 in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th January 2007, 19:51
  5. Clutch Issues? TDI QS with Revo....
    By TDI_Boy in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th June 2006, 13:34
