EM TuningSky Insurance
    Tempy's Avatar
    Aug 2012
    Kent
    148
    Dension 100/iPhone/Concert GEN II+ GSM Interference
    I have just fitted a Dension Gateway 100 to my Concert Gen II+. I didn’t like it at first as I thought you were confined to using playlists and the iPhone screen was locked down. I didn’t want this, because I wanted to be able to use the iPhone normally and pick and choose my albums, or use TomTom if I needed to. I eventually worked out how to switch the Dension into iPhone UI mode which unlocks the iPhone screen again and now I’ve got the control I want it’s actually quite a good piece of kit. You lose the DIS track info if you do this, but it’s not a deal breaker.
    I’ve hit a problem though. Last night I mounted the iPhone to the dash with a pass-through dock and I’ve had a couple of short trips and whilst it plays music very well, I get really awful GSM interference. I’m not sure if it’s the iPhone being mounted too near the Concert or if it’s the Dension adaptor tucked away behind the Concert in the dash or a combination of the two.
    Has anyone got any suggestions on how to resolve this? Putting the iPhone in airplane mode isn’t really an option as I want to be able to make/receive calls via my parrot or use the TomTom. I know a few people have fitted the Dension kit and dash mounted their iPhone. Anyone else getting this issue?
    I’ve read on the forum about possible applying some GSM shielding but not sure what I’m looking for. I could try and relocate the Dension adapter to the glovebox instead of behind the concert. Not sure if this is the issue though. This is such a shame as I was looking forward to being able to listen to my iPhone in the car again.
    Thanks.
    Audi A3 8P 2.0 TDi S-Line 140CR 3DR | Full Leather S3 Dimple Heated Interior | Dual Zone Climate Control | Black Edition Grille | Black Edition Fog Light Grilles | Dension iPhone Kit | Heated Seat Retro-Fit | Titanium Alloy Refurb | Window Tints | Parrot Bluetooth
    Plans
    Remap
    | Reverse Parking Sensors | Who Knows Where From There
    26,722
    Remove the dension from rear & have it hanging & test to see if the interference goes away, then you'll know if its the module location at fault.
    Tempy's Avatar
    Aug 2012
    Kent
    148
    Thanks Nigel. Will give that a go. The quadlock cut in cable has a little bit of length to it, not too generous, but enough to move the module. I hope that's the culprit.
    I can't imagine it's just the iPhone being near the Concert as plenty of other forum members must have dash mounted Phones and everyone would be complaining.
    Plans
    Remap
  1. dension 100 rnse help pls
    By wilf1982 in forum In-Car Entertainment
    Last Post: 7th May 2011, 21:10
  2. Dension 100 and Symphony (2008 S3)
    By AjM in forum In-Car Entertainment
    Last Post: 17th March 2010, 20:18
  3. Concert gen 1 to concert gen 2
    By brys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th November 2009, 09:37
  4. Dension 100 gateway FOR SALE
    By Oli. in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th January 2009, 21:30
  5. Help, dension 100, ipod classic and the airbag
    By robomonkey in forum In-Car Entertainment
    Last Post: 14th September 2008, 18:59
