Chris NottMonster Motorsport
Results 1 to 22 of 22
    Jun 2011
    Melbourne
    230
    Engine (coolant) temperature dipping below 90 with AC on?
    Hi guys,
    another thing I noticed today on the S3 8P. I was cruising home this eve at 80 kph with AC set at 21 deg with outside being 26 and noticed that the temp gauge was reading slightly below 90. It went back to 90 as soon as I stopped at a traffic light then did the same after I took off. I tried it with AC off and it did not budge from 90. Is this normal or I have an issue with thermostat/sensor/fans? I don't recall seeing this slight dip. I reckon it's dropping down to 87 maybe. Anyone experienced the same?
    27,126
    Dont worry to much, 87 is nothing to be concerned about, if it drops below say 60 then its usually a coolant sensor, check the readings with vcds to confirm whats on cluster is same as the direct reading.
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,420
    Mine is usually around 87C as well,so I wouldn't be concerned.
    Jun 2011
    Melbourne
    230
    Sweet. Thanks guys. Will check this weekend with VCDS.
    Nov 2012
    194
    Mine was (A4 1,9 TDI though) also sitting at 80-87 degrees.. Only 90 when acceleration a lot..
    Replaced the coolant stat.. Now it sits at 90 and stays there
    Edit: no faults showed on VCDS
    Jun 2011
    Melbourne
    230
    Quote Originally Posted by Wahlstrom View Post
    I noticed today that's its doing it even with AC off. Basically if I cruise for a while then it dips below 90 and comes back to 90 when in traffic or short distances between lights. When ac on the fans kick in and they turn off when in ECO mode of off. So if anything it might be the thermostat. Will keep an eye on it.
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,079
    I've had my thermostat replaced recently because of the same issue and it now sits at 90 all the time after warm up. Reckon you might be in the same boat it's really common on the 8p's. thermostat is only 32 quid just a pita to get to it.
    A3 Sportback 2.0 TFSI S-Line Quattro Stage 1 Tune it up - Lowestoft Custom Remap- 6187 RPM developing 260 bhp 279lbs ft Akoya Silver, Roof rails, Black heated Vienna Leather, Bose upgrade, Bluetooth
    Jun 2011
    Melbourne
    230
    Quote Originally Posted by JamesO View Post
    Any DIY available?
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,079
    Quote Originally Posted by NCRAW View Post
    Any DIY available?
    Sorry mate I had mine done by a mate, but I know he had to remove the alternator
    Jun 2011
    Melbourne
    230
    Thats cool mate. Thanks. I'm thinking about doing the timing belt too at the same time plus clean the valves and might as well change the coil packs and fuel filter. Would u know of a place in the UK where I can purchase the parts from? I live in Aus and here they charge us like wounded bull for everything.
    s3facelift09's Avatar
    Dec 2012
    124
    Today it happened for the first time on MY09 S3, the water temperature dipped slightly to 87, and then it went back to 90. And it happened 2-3 times today. How do I know is it a thermostat problem, or a temperture sensor problem? Is there a way of knowing what could be the problem. So that I don't have to buy for etc. the sensor, when the problem could be in the thermostat instead? What is more common to fail the thermostat or the sensor, in a 4 years old car, with 75k kilometers.
    autolatry's Avatar
    Jan 2013
    Yorkshire
    347
    Mine sits at 91deg not sure if it's just dodgy alignment on the dial.
    27,126
    Personally I wouldnt worry unless it drops by 10-20 imho.
    Dec 2012
    124
    Quote Originally Posted by autolatry View Post
    There is no dodgy alignments in Audi, the needle on the dial has to be on 90 C straight in micromilimeter on the line, it is a very precise and accurate dial..
    Dec 2012
    124
    But the working/operating temperature is 90 C, I would like it to be as when it was new, and if it is a sensor fail, it is possible that it could overheat(for. etc if a thermostat fails) and I would not know this because of the fail sensor..And I don't like to go in high rpm's when I haven't achieved operating temperature. Aldo if it's a sensor fail, and not a thermostat fail, the operating temperature should be 90, I'm just not getting the correct reading, correct me if I'm wrong?
    autolatry's Avatar
    Jan 2013
    Yorkshire
    347
    Oh no. Don't say there is something else up with it.
    I bet changing the thermostat on a 3.2 requires taking the car to NASA or having to burn open the housing with a special thermic lance or something equally rediculous.
    Dec 2012
    124
    It doesn't have to be a thermostat problem, it could be a temperature sensor problem also. I spoke to my mechanic friend today about the problem, we spoke shortly because he was at work, he works at the Audi dealers in my hometown, he said to me that the themostat problem on my S3 is uncommon, but possible, but he would rather take a shot at changing the sensor first. I didn't have time to ask him is there a way of knowing what is the source of the problem, before buying maybe unneeded parts, 'cause I don't want to buy a sensor if it's a thermostat problem etc... And I want to know exactly the current temperature, I want it to be accurate, and I want it to be on 90 after warming up of course. I don' think it is too much of a hassle to change the sensor or the thermostat. I will call him again tomorrow to ask him thoroughly and will post here what I will found out.
    May 2011
    24
    Hi , my S3 occasionally drops to about 87 degs . Will this affect economy and/or running ?I havent noticed a change and was going to leave fixing it until the next service or if it gets worse , Cheers for any advice ...
    c_w
    1,061
    No.
    As has been advised, start worrying that if on a motorway cruise it drops to 75 or below.
    Sep 2012
    Cape Town
    37
    Change the sensor on the right hand side of engine. I've measured temps via OBD port, if it indicates 90 on the dial, temps can vary from 83 to 97 deg and still show 90.
    Get your temps up to normal and put car in neutral, rev the engine to 2000 rpm and listen if the fan comes on. Monitor temps. If the fan comes on and the gauge is still showing low, change the temp sensor. It's giving u dud info.
    Replaced mine last month. I also change the thermostat after 5 yrs of service. Looked like new unit. Sensor was my problem.
    Dec 2012
    124
    Quote Originally Posted by Lincoln S3 View Post
    Quote Originally Posted by c_w View Post
    No.
    Quote Originally Posted by I8AGTI View Post
    I have a 4 year old S3, and I had a temperature problem this year in february. I went to the seaside on a week time vacation, I was 350 kilometers from home when I first noticed that the temperature dropped below 90 when the car already heated up, and acchieved this temperature, and this never happened before. The car was well serviced, and 6 months before I completely changed the antifreeze G12 with the new G13, there was nothing else that could be done to prolong the life of the thermostat. Aldo at first we did not know was it a thermostat or a sensor problem, it turned out to be a thermostat at the end. When the mechanic took it out it was like new but still, it was malfunctioned. After the new one was set, (and another 3 new litres of the G13 concentrated antifreeze were bought and poured ) everything went back to normal. The temperature sits now at precisely 90.
    My advice to LincolnS3 is, it's not a big problem if a temperature dips to 87 degrees, but if it's a thermostat problem, and the thermostat opens before then it should wich causes the temperature to drop, but if a thermostat closes before then it should and the temperature starts to grow over 90? What then? Does it pays off not to change the thermostat and overheat the engine somewhere on the road? I'm talking in a case if You don't pay attention to the temperature gauge and don't stop.. It's up to you..
    Boon's Avatar
    Sep 2012
    South East Kent
    428
    Seriously it is not a problem for your gauge to sit at 87 deg & how do you actually know its 87 deg anyway?!!
    The thermostat is a mechanical reaction to temperature & it doesn't open and close at precisely 90 deg
    54 8P2 A3 Sportback 2.0TDI BKD - Shark stage 1 - EGR delete - Dolphin Grey
  1. 2.0 FSI Engine Coolant Temperature Sensor Location
    By jlawie in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th January 2014, 00:31
  2. 2.0TFSI Coolant Temp - Dips below 90 degrees - Normal?
    By Minstadave in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th February 2012, 18:25
  3. S3 - P0118 - Engine coolant temperature circuit
    By Greig300 in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th July 2011, 21:51
  4. Engine Coolant Temperature Sensor (G62)
    By gaanrowl in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st December 2009, 09:55
  5. Engine coolant temperature sensor
    By liam_mcf in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st April 2009, 10:08
