AH FabricationsJMB Retrofits
    Sep 2012
    Cape Town
    37
    Generic Map/ Software loader
    Hi guys. Been searching high and low for a PC based interface or stand alone Dongle that I can put my custom maps on whenever I want.
    Currently I have to go to my Tuner and load my Race map and then I've have it flashed back straight after I'm done playing.
    I want to do it on my own without driving all the way to his spot.
    Your help will be appreciated.
    Thx.
    27,096
    Doesnt your tuner have a solution or use an alternative mapping brand that has the dongle for changing maps on the fly.
    Alternative is to get the mapping software he uses, but this wont be cheap.
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    745
    I'm not sure if you'd be able to use something like the Shark STS unit & adapt it for your needs? It seems to be a fairly generic unit that several companies use, there's one for sale in the classifieds (not mine) that could be worth investigating.
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted... Still....
    Brodster's Avatar
    Shark Performance In Scotland
    Mar 2011
    Scottish Borders
    3,402
    Follow Brodster On Twitter Add Brodster on Facebook
    The STS would work IF the tuners software was compatible with the STS and obviously if the previous owner of the STS has removed the maps that were on it. If not then its useless.
    Angelwax/BBS/BCS/Bilstein/Cobra/CTS Turbo/DTUK/H&R/K-Sport/KW/Loba/Milltek/Shark Performance/Oz Racing/TPI/VCDS/V-Maxx/Vossen/Wagner
    Sep 2012
    Cape Town
    37
    Thx for the help. It's definately something to look at.
    If i can save my pump map as a file, and then have him load my race map, I could save that as a file 2. Then have the option of choosing between the 2.
    Thx for the help. Will google and contact them.
    Jul 2007
    London
    3,238
    This will work, i am using an older version but the software is the same...Lastest Ver V12 MPPS Chip-Tuning Interface OBD2 Connector Read Write Flash + CD | eBay
    FOR SALE:
  1. What's the latest MMI software/maps?
    By IainP in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 10th February 2011, 17:08
  2. RNS-E software / maps
    By GavConner in forum In-Car Entertainment
    Last Post: 28th April 2009, 01:02
  3. Software to re-map own ECU?
    By Spacecowboy in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th April 2007, 10:36
  4. Sportec re-map
    By JayA4Turbo in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th May 2003, 12:49
  5. Demo of Revo Software
    By dbm in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st April 2003, 20:24
