Badger5EM Tuning
    210_MIH's Avatar
    Drive it like u stole it
    May 2012
    103
    A3 8P Climate Control not working properly....
    Hi Guys
    Wondering if anyones had this problem
    The dual climate control, when set on hot, only blows hot air from the drivers vents and cool from the passenger vents on the dash. even on the windscreen, hot air from drivers and cold on passengers side...
    Anyone know what this may be?
    27,096
    Sounds a flap isnt working, needs scanning with vcds to do a basic setting of the hvac 08 module, then it should bring up any flap/motor errors if existing.
    Oct 2009
    111
    You do have the passenger side temperature control set to the same temperature as the driver's side, don't you?
  1. Cruise control not working
    By gidimille in forum General Technical / How To
    Last Post: 7th December 2005, 18:32
  2. Replies: 1
    Last Post: 27th November 2005, 09:39
  3. Latest threads not working properly
    By imported_Yaseen in forum Site Support & Announcements
    Last Post: 20th February 2005, 22:50
  4. pc sound not working properly? Help
    By Dumpvalve1 in forum General Chat
    Last Post: 27th September 2004, 22:26
  5. Climate Control not blowing very cold
    By jgrand in forum General Technical / How To
    Last Post: 15th July 2004, 13:56
