Badger5Chris Nott
Results 1 to 8 of 8
    little_wing's Avatar
    Oct 2004
    Hampshire
    178
    Removing Climate Control Panel
    Does this thing just unclip or is there a particular way of releasing it? I'm fitting my denison ice link with a dashmout bracket for the cradle which clips in behind the climate controls. The dashmount instructions simply say "Unclip the climate control unit". Helpful.
    TIA.
    Re: Removing Climate Control Panel
    According to the Elsa electronic workshop manual the proceedure is as follows:
    Remove trim beneath Climatronic control unit
    Reach from underneath into centre console and release Climatronic control unit from centre console.
    I have taken mine out when I fitted a mount for my iPAQ and I pretty sure it just unclips. There are just plastic lugs that hold it back to the frame - these need to be released and the unit given a good pull.
    simonl's Avatar
    Jul 2005
    268
    remove the stereo and the climate simply pops out. Don't yank, and wrap both in a tea towel to stop them from scratching your nice glossy trim.
    IMO the brodit clip looks best raised up flush with your stereo, not lower next to the climate, this is why...
    1/The clip is exactly the same height as the stereo.
    2/The wire can be fed in to in the gap where the stereo meets the climate, so it almost completely dissapears.
    3/You don't get a big gap between the climate and the dash where the clip is forced in between.
    You're right LeMan - I did take the radio out first and the lower panel and you get get at the climate control from above and below.
    Mine is a Brodit holder for the iPAQ but not fixed to a Brodit mount on the car. I personally prefer the lower mounting position.
    Oct 2004
    Hampshire
    178
    Cheers for that - I'll try not to break anything in my usual cack handed manner...
    I've just remember I took some photos when I removed the Climate panel and radio on my A3. They may be of some interest...
    photo 1
    photo 2
    photo 3
    photo 4
    Jul 2005
    2,488
    [ QUOTE ]
    [/ QUOTE ]
    hahaha i know what you mean there, it like, its aaaaaalll going *crack*
    sh!t.
    Oct 2004
    Hampshire
    178
    Thanks for the help guys - nice pics, David.
    I decided to go for the lower mounting a) because there's a screw that the dashmount uses to hold it in a little more securely and b) because when I tried it up near the stereo, there is some interference with the controls (FM, CD and volume/on/off knob).
    Don't think I've broken anything (which is probably a first), stereo works, but can't test the Ice Link yet as my iPod hasn't arrived yet [img]/ubbthreads/images/graemlins/frown.gif[/img]
    For me, that's a success!
