AH FabricationsEM Tuning
    Jonse's Avatar
    Oct 2012
    353
    RNSE GPS questions. Please help :(
    Hi All,
    I have fitted my rnse unit and all is working well expect the GPS. When using the sat nav it tells me i have 7 satellites, but my position is always around 50 meters behind of where i am, and then when i change direction it goes off road.
    I have done some searching into this and people mention that it could be do with your wheel size and changing settings in vag com.
    I then went into engineering mode to see what settings i had:
    Could someone please tell me if there right?
    I have also seen that people are saying that you need to drive for several hundred miles for it all to calibrate.
    Any help would be great.
    Ryan
    26,716
    Just drive it around for a day, it will settle mate, you have to give it a bit of time as its always of by that much when 1st connected up.
    Jonse's Avatar
    Oct 2012
    353
    Ahh ok brilliant, just wasnt sure if i had missed a setting that was causing it to be out
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,073
    Yeah as Nige said, common this is, people thinking there is something wrong. There is a setting in adaption that allows you to put your correct wheel size, but from experience and am sure others will back me, most people leave this as the satnav will soon calibrate it self.
    Dont panic mate, you will be fine.
    VCDS Owner-North London/Enfield
    " To Cruise Is What I Do"
    Jonse's Avatar
    Oct 2012
    353
    Thanks im feeling alot better about this now
  1. Centre Arm Rest questions .... please help ?
    By sukrw in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th December 2007, 16:23
  2. Problem questions.. please help?
    By New2Audi in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th June 2007, 00:25
  3. 2000 S4 Question...PLEASE HELP!!!!!!!
    By imported_ipasgas1 in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th September 2004, 07:42
  4. A4 Convertable questions - please help!!
    By imported_senna555 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th August 2004, 12:08
  5. Audi stereo question - please help!!!! Concert to Symphony
    By ajmackie in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th May 2004, 14:45
