Monster MotorsportEM Tuning
Results 1 to 15 of 15
    Dec 2012
    32
    1 fault code found during service and no fault light displayed on dash... help!
    Hi all,
    I just got my car serviced at AMD Essex, I have to mention, they provided fantastic customer service! Anyhows...
    1 fault code was found during the service:
    17748: Camshaft position sensor (g40) / engine speed sensor (g28)
    p1340 - 001 - incor. correlation
    readiness: 0110 1101
    No engine light on or any other fault lights and car runs fine.
    However, AMD tech guy did mention it could be that the chain has stretched.
    thoughts anyone???
    27,079
    Assume its a 3.2 then?
    Dec 2012
    32
    yes 3.2
    27,079
    Urm thats not good huh.
    chris.vincent3's Avatar
    Apr 2012
    UK, Portsmouth
    601
    Hard to say without someone reading the codes into more depth using VCDS for example. But, it is completely possible for them to be old faults that haven't been cleared.
    As for the chain stretching, when was it last changed? Due to be changed soon?
    27,079
    This is true, but in ideal world you'd expect them to have tried to clear & then if comeback, tell you, problem is,this worlds far from ideal & not even all dealers do this, so chances with indy's is even less unfortunately.
    I always scan before/after to protect myself in 1st instance & also help client out should they have a pre-existing fault.
    Apr 2012
    UK, Portsmouth
    601
    Yeah, unfortunately things do get forgotten. Digikam, if your chain isn't due to be changed or has recently been changed, i'd seek help from someone that could scan it for you, and just hope the faults don't come back.
    Yeah Danny did that when he fitted my cruise control, he knew my boot light had been unplugged (from having the boot open in the forecourt) otherwise I'd probably not have known to this day now.
    Dec 2012
    32
    Quote Originally Posted by chris.vincent3 View Post
    engine light has now come on!. i find it strange for it to happen after service. first time i seen the engine light since purchase. car was purchased recently so not sure if chain was replaced.
    my brother will be taking the car to his mates garage tomorrow so will see what that returns. he has all the tools to check.
    27,079
    Chain isnt changed, its a lifetime part, but the chain stretches & its a boat load to fix, here's one link:
    A3 3.2 - Dreaded Cam Chain Stretch - PistonHeads
    Dec 2012
    32
    Amd quoted me 1200 for parts and labour to fix this but again i am not sure if the chain is the problem. Are there any obvious visual/sound signs for this problem?
    27,079
    Either they're underestimating the problem or they've got the wrong fault, I remember Paddy spending 10k to find his fault on a car not even worth maybe half that now.
    Dec 2012
    32
    They mentiond as mine is dsg, apparently labour should not be as intensive as doing a manual model
    Apr 2012
    UK, Portsmouth
    601
    Quote Originally Posted by digikam View Post
    Never knew the chain was a lifetime item as they obviously stretch. I was told that when they get noisy it's a symptom they need changing, however I was under the impression that the chains where replaced not as often as a belt just regularly throughout the engines life so what I know isn't of much help unfortunately as I could be wrong.
    But a stretched chain will put the timing out and make it run like a bag of nails, but other things could also make it run bad, it would be a massive assumption to believe its the chain but if its a common problem and by the sound of it, it is and it's already been diagnosed as the chain you might want to look at replacing it unfortunately.
    Dec 2012
    32
    the car runs near perfect... just need to replace the exhaust to fix the leak on the flex section. engine sound is normal.. no rattles etc.
    the garage have assumed its a stretched chain because they seen the same fault on other cars and apparently it went away when they replaced the chain.
    Dec 2012
    32
    good news! just got an as new catalytic converter fitted to my car at nirro. total cost including part came to 290. car running very smooth now and vagcom has returned no faults. looks like the blown flexi was causing the series of faults that occured before.
  1. ESP fault code 01435 Brake Pressure Sensor - Common fault apparently
    By DenniS3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th June 2012, 13:50
  2. Replies: 2
    Last Post: 19th December 2010, 20:41
  3. air bag light on and faulty brake light warning on dash ?
    By theviking in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th March 2010, 17:45
  4. 2 fault codes found? Help/Advice needed.
    By AidenUK in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th February 2010, 19:14
  5. FAULT CODE FOUND...
    By Izzy1 in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th October 2008, 16:30
