Monster MotorsportEM Tuning
Thread: Spooky sat-nav
    Mar 2011
    Cleveland
    979
    Spooky sat-nav
    Any-one had this happen to them?
    Stopped the car today with my rns-e radio on. Switched off engine and removed key. Radio keeps playing, but with the set totally dark, no illumination at all! No response from any control on the sat-nav or wheel! No volume, re-boot, nothing. After about 5 minutes it stopped playing, so we locked the car and went shopping. Came back a couple of hours later and everything was normal!
    Ghosts in the machine???
    27,093
    Just do a reset with radio & setup button held until everything goes of, see if that helps it & also reload the firmware.
    Mar 2011
    Cleveland
    979
    Cheers, I'll do that.
    It was just so scary, like some entity had taken it over. I pressed every single button, switched every switch, locked and unlocked the doors but nothing - short of disconnecting the battery - would have stopped it!
    The weirdest part was that there was nothing at all lit on the sat-nav.
  1. New Sat Nav Plus - available first on new A3s
    By jamesa in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th September 2003, 22:30
  2. Sat-Nav and GPS Camera positions
    By mramage in forum Other Brands & Models
    Last Post: 8th August 2003, 14:34
  3. Sat-Nav System
    By Mo-S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th April 2003, 20:05
  4. Sat Nav
    By Nimo in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd April 2003, 23:45
