Sky InsuranceJMB Retrofits
    Apr 2011
    Somerset
    72
    Help, damp passenger footwell
    Hey everyone,
    Done a bit of a search but couldn't find anything specific on this issue so sorry if its already been answered.
    Washed the car yesterday and noticed when I went to clean inside that the passenger footwell was very wet! Haven't had any previous problems with water getting in but did a bit of investigating today to see what I could find. I removed the windscreen trim and noticed that there was a lot a black silicone seal hanging off it and no other obvious signs of blocked drains etc!
    My question is can water escape bk up past the windscreen into the footwell? Or are there other common places where it leaks?
    I have a 58 a3 sline
    27,094
    Could just be a door seal worn mate & when water drains round door it goes into seal & out the bottom, have a looksy.
    Apr 2011
    Somerset
    72
    Thanks will have a look when it's light again, seals shouldn't perish that quick though unless there's a cut in.
    27,094
    Depends on if there's been a mnafacturing defect, enviroment, etc, not saying its this, but it has been known to do this & think about where that water would go at bottom of door should seal be faulty, straight onto/under carpet.
  1. Damp passenger footwell
    By subtle in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th January 2011, 16:56
  2. Steam coming through the vents and wet passenger footwell...HELP!!
    By Higgsy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd June 2010, 17:15
  3. Damp passenger footwell
    By jay_w in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th January 2010, 21:14
  4. Leak in passenger footwell
    By tommyK in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd June 2007, 20:44
  5. water leaking passenger footwell
    By solihul in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th April 2006, 21:43
