Sky InsuranceBadger5
Results 1 to 8 of 8
    adz195's Avatar
    Sep 2012
    Auto lights / wipers retro fit advice
    Hi all need some advice on a mirror for auto lights wipers. I have got a mirror from a mate pn#8R0571511. Will this be ok for a 2011 a3 8P. Been searching google and some say yes some say no. Thanks in advance.
    27,075
    Part numbers wrong, its 8R0857511 & comes up as auto anti dazzle for the 8P range yes.
    You need an installer for the system or doing yourself mate?
    adz195's Avatar
    Sep 2012
    Ok thanks mate. Ill have to check the number on the mirror. Probably going to fit it myself. Got a new screen being fitted next week because of a massive stone chip so thought I may aswell go for it.
    adz195's Avatar
    Sep 2012
    Hi I've started fitting the auto light wipers. I have connected the kufatec loom to ce plug b pin 33 (Lin bus loom) and plug c pin 28 (backup signal) and lgnition plus and steady plus to the fuse board. Connected the gnd. Activated in vcds (rls) now the head light switch has an extra plug on the old one that I don't no where go's (little plug with one red and black wire). my lights are always on and get an error say auto lights wiper deactive.
    27,075
    You need to purchase the auto version that is for your year/car as that extra connection was added to newer cars.
    adz195's Avatar
    Sep 2012
    Ok thanks. Is there any other wires I have to connect do you know?
    27,075
    If using a kufatec loom then pray its fully wired properly, but as I dont know what they have supplied I wouldnt like to speculate.
    You need the correct switch 1st before condemning any wiring.
    adz195's Avatar
    Sep 2012
    Hi ive got the correct light switch now. Ive pluged it in and its still not working got the error log: Address 09: Cent. Elect. Labels: 8P0-907-063.clb
    Control Module Part Number: 8P0 907 063 G HW: 8P0 907 063 G
    Component and/or Version: BCM PQ35 M 107 0615
    Software Coding: 4E000A2FA005F000207041E00000094C461E25AA206DD12AE4 008F840041
    Work Shop Code: WSC 06314 123 12345
    VCID: 387B2CD33093
    Fault Codes have been Erased
    2 Faults Found:
    01800 - Light Switch (E1)
    008 - Implausible Signal
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 217
    Mileage: 30576 km
    Time Indication: 0
    Date: 2013.01.23
    Time: 18:42:27
    Freeze Frame:
    Term 15 On
    Voltage: 12.00 V
    ON
    ON
    Term 50 On
    OFF
    OFF
    01520 - Rain and Light Recognition Sensor (G397)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 217
    Mileage: 30576 km
    Time Indication: 0
    Date: 2013.01.23
    Time: 18:42:27
    Freeze Frame:
    Term 15 On
    Voltage: 12.00 V
    ON
    ON
    Term 50 On
    OFF
    OFF
    I have also checked and I have the wire for pin 2 10 pin connecter to pin 20 a 52 as I have bi xenon with led lights (standard)
  1. How easy is it to retrofit auto lights&wipers?
    By boggysv in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd February 2013, 22:11
  2. Help with part numbers for auto lights/wipers retro fit
    By rob_watti in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th May 2012, 23:04
  3. Retro-fit auto lights / wipers?
    By Ben H in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd July 2011, 10:56
  4. How to fit Auto Lights/Wipers & Auto Dim Mirror to 2006 RS4
    By JR Tuning Ltd in forum General Technical / How To
    Last Post: 20th November 2010, 19:02
  5. Auto Lights/Wipers v Manual Lights/Wipers
    By A3_SSS in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th July 2009, 13:32
