Sky InsuranceAH Fabrications
Results 1 to 27 of 27
Thread: cruise contro;
    Oct 2012
    490
    cruise contro;
    what best sort of price to fit cruise control into my a3 56 plate s line?
    a3_sline_tdi's Avatar
    Aug 2009
    903
    £150-£160
    Current
    2006 56 A3 S Line 2.0 TFSI Special Edition Moro Blue
    previous
    2007 A3 S Line 2.0 TDI 170 S-tronic phantom black
    2006 VW Golf Gti Black
    2008 S3 Dolphin Grey
    2007 A3 S Line 2.0 TFSI S-Tronic Ibis White
    2005 A3 S Line 2.0 TDI S-tronic Brilliant Red
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    14,389
    Quote Originally Posted by southylad View Post
    where are you located? There are a few sponsors on here that can do this for you. x
    Smaller (Local) Events
    Audi-Sport.net online magazine.
    To find Audi-Sport-Net members with VCDS check out the MAP.
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,077
    I am in North London mate if any good to you?
    VCDS Owner-North London/Enfield
    " To Cruise Is What I Do"
    Oct 2012
    490
    i am up north in lakes near barrow in furness
    Oct 2012
    490
    Quote Originally Posted by a3_sline_tdi View Post
    £150-£160
    that would not be a bad price if there was someone up this end
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    14,389
    Contact NHN, he travels all over the country doing retrofit work and is also a site sponsor. x
    Sep 2011
    Reading
    50
    dannykn9 is your man he's in Enfield!
    Lewis583's Avatar
    Mar 2010
    836
    cruise contro;
    £150-£160
    Not if he requires a new steering ecu. When I retrofitted cruise I got the ecu for £130 with discount.
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    Fossie
    Rhubarb Triangle
    3,961
    Quote Originally Posted by Lewis583 View Post
    Won't need a new ecu if the car has DIS. New steering module is usually only needed for mfsw.
    Lewis583's Avatar
    Mar 2010
    836
    cruise contro;
    I know if its got DIS, which it should being an S-line, it will work. However, this you know, if its got a midline ecu the cruise will have limited functionality. I.e. buttons not working etc. don't know about you but I prefer to not do half a job.
    Full VCDS
    Fossie
    Rhubarb Triangle
    3,961
    Sorry Lewis but that is not correct. All the functions of cruise control work but in the 'alternative' mode. I know because when I fitted CC a couple of years ago to my 2006 sportback it worked this way. The only button that does not work is the 'set' button at the end of the stalk. You set it by flicking the arm downwards at the desired speed after pulling towards you to activate. From then on, upwards to increase speed, downwards to reduce, away to deselect and towards to select again.
    This is quite natural to use and certainly does not warrant buying another ecu. However, should you wish to fit mfsw as well then only one module (actually 2 now I think) will work and ,when fitted, the CC operates in the 'normal' mode.
    Lewis583's Avatar
    Mar 2010
    836
    I could perhaps have worded it better, my mistake. But that is what I meant, the button not working. If I were going to the effort of having it retrofitted I would want all buttons to work, but that's just me.
    Oh and "normal mode" FTW!
    Full VCDS
    Fossie
    Rhubarb Triangle
    3,961
    Lewis mate, I'm not sure if you have taken offence at my post but if you have I'm sorry.
    If you were prepared to spend £130 extra just to get cruise working with the 'set' button then fair enough. Personally I retro fitted CC with my original ecu not knowing it wouldn't work with the 'set' button. After happily using it and then deciding to fit mfsw I knew I needed the correct steering module and realised there were two different ways for CC to work.
    This is now well known by all the professional 'retro-fitters' on this forum and , no doubt, they would confirm my comments.
    'Normal Mode' and 'Alternative mode' have been generally accepted by the expert retro-fitters on here so I'm not sure what your problem is ??!!
    However, I never did know what 'FTW' meant but I assume it isn't an anagram of 'WTF' !!!
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,077
    Yep I can 100% back mike up as I would consider myself a bit of a cruise retrofit expert :-).
    But I must add, that since the OP stated he has a 56 plate (late 2006/7) 99% his midline ECU will either be the 1K0 AH or an 8P0 module which both will accept the cruise in the correct manner.
    I think from around 2006 onwards, most A3's with Trip computer came with the above said modules. It was only really 2004 to late 2005/6 that had the alternative working cruise modules.
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,077
    £130 with discount is a bit of a waste TBH mate, especially when you can pick up a used one on eBay for around £80.
    Fossie
    Rhubarb Triangle
    3,961
    Thanks Danny - I can confirm that my 2006MY sportback had 1K0 rev AF so operated in 'Alt' mode
    What does 'FTW' mean please? Hope it's not so bloody obvious I should know !!!!!!!!
    Be kind, I'm a pensioner !!
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,077
    Lol Mike.
    FTW= For The Win.
    He was basically saying, having cruise work the correct way gets his vote.
    Fossie
    Rhubarb Triangle
    3,961
    Quote Originally Posted by Dannykn9 View Post
    Lol Mike.
    FTW= For The Win.
    Thanks again Danny - as far as I was concerned, getting it it to work at all was an FTW then !
    8P0 rev 'F' and mfsw must have been an FTWW then (win win ) !!!!
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,077
    Haha, no worries Mike.
    Lewis583's Avatar
    Mar 2010
    836
    Lol, no offence taken fella. I work in the trade so have developed a thick skin and life is far too short to take offence on the internet.
    I wouldn't call the 130£ a waste in my opinion of course, as in future I can always fit a MFSW should I please. Also the "Oh and "normal mode" FTW!" was an attempt to lighten it up a tad. Alas, I shall go back to my corner
    Full VCDS
    26,776
    Its finding them which is the fun part, they're few & far between, which is why is most of my clients cant be arsed & get new as they want it working completely & now, stands to reason as you could bid on one on ebay, either miss out & start again or bid, win & it be faulty for some obscure reason lol.
    Fossie
    Rhubarb Triangle
    3,961
    Bet this doesn't last long !!!! Just posted today :-
    AUDI A3(8P),TT(8J),GOLF MK5, MULTIFUNCTION STEERING WHEEL MODULE 8P0953549F | eBay
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,077
    Sold!!
    Fossie
    Rhubarb Triangle
    3,961
    Sold!!
    To you ????
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,077
    To you ????
    Now that would be telling ;-)
  28. #27
    Fossie
    Rhubarb Triangle
    3,961
    I got it emailed to me at 12:59 - bet you didn't see it before then !!!!
    Edit : sorry, should have put 'lol' after ! I posted to give all a chance so hopefully one of us got it !!!
  1. cruise control retro-fit
    By yoda01 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th June 2010, 15:11
  2. CRUISE CONTROL, CAN IT BE DONE?
    By blackwood in forum General Technical / How To
    Last Post: 2nd October 2004, 15:20
  3. Retro fitting cruise control
    By Anito in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd April 2004, 10:35
  4. Cruise Control,
    By t955daytona in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th October 2003, 20:45
  5. Retrofit Cruise Control
    By Nimo in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st February 2003, 16:08
