Sky InsuranceJMB Retrofits
    Sep 2012
    Electrical issues?
    Hello all!
    I have been in ownership of a 2 litre diesel A3 for last couple of months which has been great however recently the alarm has been going off spontaneously and the tailgate open light is always on, on the dash. Having looked at other threads I see that this seems to be a fairly common problem, and the likely problem is the tailgate lock mechanism resulting from a leaky washer so I plan to look at this. I have still been driving the car, just not been arming the alarm. Now im finding that the airbag light comes on intermittent ly and also the indicators periodically go funny I.e sometimes indicating right will cause both indicators to flash bizarrely. Any ideas, any connection between these problems?
    27,038
    Yes clean up the bootlid of water ingress & dry it out, then see if any corrosion is there, fix this then see if the problems go, you may have some water leaked over the convenience module that sits in he rear drivers quarter, so a pipe may have come loose or broken.
    If you need it looked at, give me a shout.
  1. Ongoing Alarm/electrical issues UPDATE
    By Westy in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th May 2011, 13:53
  2. Electric issues
    By steady jay in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th February 2011, 01:00
  3. More Coolant/Electrical Issues?
    By Ronniebiggs in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 29th January 2011, 23:06
  4. Electrical issue !!!
    By jimiboboyo in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd April 2010, 14:22
  5. Electrical issues
    By Hangn69 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th February 2010, 19:36
