Volks AutosMonster Motorsport
    Alex C's Avatar
    Lizard, Cornwall
    2,562
    2.0 Litre TFSI - Knocking noise in head
    Hi,
    a request for help
    My brother in London has a 2.0l TFSI A3 Quattro 2006.
    He is complaining of a regular knocking noise coming from the cylinder head and using a screw driver he has narrowed it down to the gearbox side of the head. He has all ready replaced the cam follower for the high pressure fuel pump and it showed no signs of excessive wear. He is fairly familiar with cars and says that it is a knocking noise rather than tappets or the sound of a loose cam chain.
    He has asked me to send him some Elsawin pictures because despite some knowledge he is not familiar with the TFSI engine and the additional lumps of metal stuck on the end of the cylinder head (gearbox end). From the elsawin picture attached #9 (Exhauster pump) and #17 (Housing) he is unfamiliar with. So, number 17 is the housing for the high pressure fuel pump? And what is an exhauster pump and what does it do? And could any of these result in a knocking noise?
    Also, for my benefit now, what is part #4 described as valve housing? is it part of a PCV system?
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    A3 SportBack 2TFSI quattro DSG
    Jul 2009
    Norway
    220
    Hi Alex.
    Take a look at this...
    http://vw.nate-online.com/techdocs/2.0L%20FSI.pdf
    If I am not mistaking your brother have the old style enging with cam belt. Right?
    If he has the new CCZA with chain timing gears try this one....
    http://www.vaglinks.com/Docs/VW/Misc...SSP_824803.pdf
    Good luck.
    Best regards
    J$B
    Norway
    Alex C's Avatar
    Lizard, Cornwall
    2,562
    Awesome thanks for that! That should help him out a lot
    Alex S3 AMK
  1. Knocking noise !
    By imported_ANNANBHOY in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th July 2005, 16:02
  2. knocking noise from front after lowering car
    By TDI in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th July 2005, 18:16
  3. knocking noise
    By chrisa4quat in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st September 2004, 23:26
  4. CLUTCH KNOCKING NOISE
    By imported_cudwuss in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th September 2004, 19:43
  5. Knocking Noise
    By L1ARR in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th September 2003, 17:19
