Results 1 to 31 of 31
    tdi-man's Avatar
    Jul 2009
    1,587
    Major problem any advice please
    First of all car drives and runs fine ticks over fine oils fine powers fine. PROBELM IS WHEN I LEAVE CAR AFTER A RUN FOR SAY 20 - 40 MINS AND GO BACK to car and start it sometimes smokes like a pig but not every time for a short while then clears and all is fine . turbos 14 months old so am thinking of taking it of and getting it checked under warrenty ?
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs / Oil catch can
    233 bhp - 309 ft lb - 419 nm
    FLYWHEEL + HELIX CLUTCH KIT FOR SALE
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    682
    MAJOR PROBELM ANY ADVICE PLEASE
    Valve stem seals? Or injector seals? Only takes a small amount of oil to seep into the cylinders when not running for it to produce a cloud at startup. This wouldn't be noticeable when running as the cylinder pressure would force any leaks out rather than in, seen similar things happen on a couple cars that ran really poor or 'home brew' fuels that eat away at the seals.
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted!
    Bits for sale...
    Genuine S-line 18" alloys, A3 Sportback rear lights. A3 5dr window switches & mirror switch. , Brand new PD170 engine cover. PM for details.
    tdi-man's Avatar
    Jul 2009
    1,587
    ok just left it for 30 mins and started it and no smoke left for an hour and started it and no smoke. changed injectors 2 years ago and put new seals in ?
    tdi-man's Avatar
    Jul 2009
    1,587
    just checked head number and is a C
    Acheron's Avatar
    Jan 2012
    South Africa
    263
    What colour is the smoke, does it have a distinctive smell?
    Current: 2010 Audi S3 Sportback S-tronic
    Ex: 2007 Audi A3 Sportback - 2.0T DSG
    Ex: 2008 Opel Corsa OPC
    Ex: 2004 Opel Corsa Lite
    Ex: 1978 VW Beetle
    tdi-man's Avatar
    Jul 2009
    1,587
    I would say whitish blue not black. hant noticed smell will get a video next time and have a sniff.
    tdi-man's Avatar
    Jul 2009
    1,587
    tdi-man's Avatar
    Jul 2009
    1,587
    uploaded a video out side temp is +10c engine is 75c
    tdi-man's Avatar
    Jul 2009
    1,587
    max69vk's Avatar
    Apr 2012
    682
    Ok, that definitely looks like water vapour rather than anything else, have you noticed the header water level dropping over a period time?
    Bits for sale...
    tdi-man's Avatar
    Jul 2009
    1,587
    yes but not a lot and doesn't smoke all the time.
    max69vk's Avatar
    Apr 2012
    682
    Just had a thought! Have you checked the EGR & EGR cooler? 2006 PD EGR Cooler leak - TDIClub Forums
    Bits for sale...
    tdi-man's Avatar
    Jul 2009
    1,587
    egr is blanked of and replaced egr cooler coulpe years ago but have been thinking about removing it completely.
    tdi-man's Avatar
    Jul 2009
    1,587
    how easy to removing egr cooler might try this first
    26,720
    EGR cooler is on back of engine, top right if its the bkd, little pita to get to, ideally need on a ramp to unbolt it all & thats a fair bit of smoke, cant work out that metallic noise, but egr cooler is a known one & if its using coolant that you notice then must be leaking somewhere & obviously that smoke denotes it, need to research egr mate & also head.
    I have a similar issue myself but only 1st thing starting, it goes within few seconds & its non existent on warm mornings, I still have to check my systems, just havnt had time, I suspect gasket, head or egr atm as my coolant usage is tiny but noticeable.
    tdi-man's Avatar
    Jul 2009
    1,587
    tdi-man's Avatar
    Jul 2009
    1,587
    not sur if to get turbo checked ?
    tdi-man's Avatar
    Jul 2009
    1,587
    ordered egr cooler delete kit and will see what happens.
    26,720
    Dont forget needs mapping out.
    tdi-man's Avatar
    Jul 2009
    1,587
    egr is already mapped out and blanked of so going to remove the cooler .
    tdi-man's Avatar
    Jul 2009
    1,587
    does not smoke first thing in morning
    tdi-man's Avatar
    Jul 2009
    1,587
    been told that it could be the injector seals leaking ? ANY COMENTS.
    max69vk's Avatar
    Apr 2012
    682
    I did mention that previously, but the smoke from the rear seems too white for it too be burning oil or excessive fuel. Your best bet is to get a compression test done & see if that shows anything irregular.
    Bits for sale...
    tdi-man's Avatar
    Jul 2009
    1,587
    had oil and filter service with oil flush and also had the egr cooler removed and all seams ok for the last week any way
    tdi-man's Avatar
    Jul 2009
    1,587
    update .
    still smoking once car was got upto temp
    car passed mot at first rev emissions test showed 1.5
    when reving for test no signs of smoke
    COULD THE PISTON RINGS BE GONE OR VALVE STEM SEALS ? when taking oil filler cap of its chuffing abit
    HEAD WAS CHANGED 120,000 miles ago
    CAR HAS DONE 200,000
    starts fine first time every time
    can any body do a compression test on this for me
    doesnt use water or oil
    tdi-man's Avatar
    Jul 2009
    1,587
    also wheres the pcv system on these ? crankcase breather ?
    thanks
  28. #27
    sliced's Avatar
    Drive safe, stay alive.
    Jun 2012
    1,161
    looks like i win :$
    Video0015 - YouTube
  29. #28
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,621
    Looks like steam to me ..check your exhaust system for holes\leaks taking on water?
    2009 A3 SB 2.0T DSG S line
  30. #29
    tdi-man's Avatar
    Jul 2009
    1,587
    any body
  31. #30
    sliced's Avatar
    Jun 2012
    1,161
    did you end up fitting a new engine?!
  32. #31
    tdi-man's Avatar
    Jul 2009
    1,587
    next week removing reconing and refitting
  1. big problems, any advice please ?
    By jamieA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th September 2012, 09:18
  2. A3 braking/abs light problems any advice please?
    By craigd in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd February 2010, 21:10
  3. Buying New - any advice please
    By RGS3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st May 2007, 18:50
  4. B6 S4 manual clutch failure - anyone else? - any advice please
    By imported_Teutonic_Tamer in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th January 2006, 12:35
  5. Cutting out problems, any advice?
    By imported_smoke in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th December 2005, 18:16
