EM TuningSky Insurance
Results 1 to 9 of 9
    TDI140's Avatar
    May 2011
    1,293
    can you spray paint your intercooler ?? if so how ??
    ^^^^can the intercooler be spray painter silver using metal spray paint so i dont have to primer it ?
    i wish to spray it to give it more of a outstanding and youthful look as it looks a bit dingy, dark and glum
    A3 2.0TDI FWD sportback with GT1756 225bhp 351ft lb, forge boost hoses red, milltek decat system, BMC panel filter, golf gti edition 30 full front brakes brembo pads, black honeycomb grill, full oem s line kit + cupra r lip, LED side lights, OEM xenons, LED interior lighting, LED A8 number plate lights, boost gauge, alloy catch can with red hoses, FBSW, windows tinted, de-badged, now on air ride with chassis notch
    Alex_Dubz's Avatar
    Dec 2012
    Bucharest, Romania
    23
    Liquid paint won't last on aluminium no matter what you do. Only powder coating but i think that would affect the heat transfer. I would just remove it and clean it well if i were you, or polish it :D
    Jan 2012
    367
    As above, unless it's done properly you will affect the way it works. Remove it and get it shot blasted?
    TDI140's Avatar
    May 2011
    1,293
    oh right so adding a coat of paint or even powder coating will effect the cooling of the car ? thats a bit of a bummer as i dont want to fit an s3 aluminium intercooler heard its a lot of work and obviously the price tag and the question of not needing it as my car isnt running high enough boost/power
    looks like ill be leaving that exactly how it is then
    thanks for the quick responses
    gixerson's Avatar
    Jul 2012
    Athens, Greece
    122
    I went the other way on my MX5, painted the IC black so it wasn't so obvious
    10 years on with daily use and a pretty regular track thrashing and the paint hasn't pealed or come off.
    Did some temp readings before and after and it made absolutely no difference to intake temps.
    Should point out that i am in Greece so that's 10 summer of mid 40c's ambient temps.
    You can paint aluminium, you just need to get the right paint and primer.
    I used high temp paint the same as i used on my cam cover and supercharger, again no problems on either with peeling or paint coming off.
    Alex_Dubz's Avatar
    Dec 2012
    Bucharest, Romania
    23
    I painted the valve cover and intake manifold on my 1.8T and the 16v i had in the past, always high temp paint, with and without primer, failed in every way, i can scratch the paint with my nail. Next time i'll go for powder coating for aluminium.
    gixerson's Avatar
    Jul 2012
    Athens, Greece
    122
    Quote Originally Posted by Alex_Dubz View Post
    Aluminium is no different to steel, many cars my MX5 included use aluminium panels again with absolutely no problems.
    The key is to make sure the surface is absolutely spotlessly clean, for cam covers you also need to go over and give it an extremely thorough degreasing, then go over with a scouring pad to give the paint a good key.
    Etching primer is also a good idea if you've had problems before.
    I can say that my aluminium IC that has been painted for 10 years cleans up as good as new, as does my cam cover and supercharger.
    Worth pointing out that my supercharger regularly hits 200c after hard use, again absolutely no problems.
    It's all in the preparation
    TDI140's Avatar
    May 2011
    1,293
    did you paint all the front of the intercooler ? or just the sides ? as i wish to have the whole think looking shiny and fresh if its a good look, or i could buy a forge utensil and paint forge on the black intercooler using red high temp paint ???? ideas ???
    gixerson's Avatar
    Jul 2012
    Athens, Greece
    122
    I painted it all.
  1. How can you tell when your AC needs re charging/re gassing?
    By AidenUK in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th November 2011, 08:51
  2. Can you tell if your S3 has been chipped ?
    By Jasdent in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd May 2007, 17:44
  3. how can you tell if your phone is broadband
    By 205man in forum General Chat
    Last Post: 21st May 2007, 10:11
  4. Would you paint your calipers?
    By steeve in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th January 2005, 17:25
  5. How can you test if your clutch is on its way out?
    By MingBluS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th February 2004, 18:35
