Chris NottAH Fabrications
Results 1 to 15 of 15
    Dec 2012
    47
    newbie just bought A3 T fsi dsg 2006....advice please
    hi guys new to this forum and audi.
    just bought an A3 2T fsi sline special edition dsg. 1 lady owner with 50k on a 56 plate.
    lovely car and so far im happy...just wanted to know if there is anything to look out for? or needs changing at this mileage?
    im getting the dsg oil changed tomo, and its going in for a recall on thursday(coilpack i think),
    is there anything else i should do or look out for? iv read parts on the camshaft follower but unsure what that is.
    also is it worth getting a warranty from warranty direct or warrantywise?
    many thanks
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    14,276
    Hi, welcome to audi-sport, the boys will be along shortly to advise you. Have a read through the faqs threads, loys of info in there. Enjoy the forum. x
    Smaller (Local) Events
    Audi-Sport.net online magazine.
    To find Audi-Sport-Net members with VCDS check out the MAP.
    daz5182's Avatar
    Nov 2012
    Newark UK
    142
    Re: newbie just bought A3 T fsi dsg 2006....advice please
    Look out for the mechatronics unit on the dsg gearbox. Common problem, just had mine done on warranty.
    Dec 2012
    47
    Quote Originally Posted by daz5182 View Post
    Cheers,
    What's the mileage on your car? Is it worth me getting a warranty? From direct or wise? I'm going to ask audi tomorrow if thwy do any warranties.
    Aug 2008
    134
    You'll need to get the Cambelt done at 60k, it's usual to change the water pump at the same time as it's all connected AFAIK. Brake fluid, Air filter and spark plugs every 2 years I think.
    I'm not sure warranties are terribly good value as they won't cover stuff considered to be wear and tear.
    I've had mine 3 years and have just had the cambelt & DSG oil done as I've decided I like it so much I'll keep it another couple of years.
    8P2 A3 2.0T FSI S line Special Edition Sportback S tronic 2007MY. Black. Concert II+ & Bose.
    Dec 2012
    47
    Thanks for the replies.
    Warranty direct said they do cover for wear and tair. Ill have to look through the small print.
    Any info on the cam follower , iv seen a few threads on that.
    JPK
    May 2012
    278
    1. Check cam follower for wear and replace it if there is anything at all, its a cheap part - behind HPFP (high pressure fuel pump)
    2. Replace diverter valve with revision D if it hasnt already been done. There are prone to failure, even on standard boost
    3. Cambelt and water pump if it hasnt been done yet. They recommend every 62,000 miles or 5 years from memory. Do thermostat
    whilst you're in there.
    There is a few other minor things but the above and the DSG service would be the main things. Gearbox should be fine if its a 2006, I believe there was less problems on these than the 7 speed dry clutch versions that came out a couple of years later, maintenance is key and try not to overheat the DSG by strongly feathering/pulsing the throttle reversing up hills etc.
    daz5182's Avatar
    Nov 2012
    Newark UK
    142
    Yeah warranty, Audi prices are silly to say the least, 95 per hour labour plus parts for the mechatronics unit....
    daz5182's Avatar
    Nov 2012
    Newark UK
    142
    My warranty was from the AA and is excellent, had a warranty direct one before and they weren't as good.
    Dec 2012
    47
    thanks guys, I'll take a look at AS warranty. getting gearbox oil change next week, and I'll get cam follower done too.
    Jon
    Fossie
    Rhubarb Triangle
    3,961
    I have Warranty Direct and have no problems at all. Replaced turbo without question. For a new account they cover for wear and tear after three months. From then on, including renewals, it's covered at all times.
    Jan 2013
    7
    If you don't mine me asking, how much did you pay for the car?
    Dec 2012
    47
    Quote Originally Posted by bradders1stfc View Post
    i paid 8k for it, special edition so has all the extras too. is that a fair price?
    ill have a look at warranty direct small print too, i thought they where good due to the wear and tear cover.
    thanks
    Jan 2013
    7
    Quote Originally Posted by jondsg View Post
    thanks
    I'm looking at a similar car but tdi with 48k and it's not special edition!
    Was wondering what it's worth and how much I should pay?
    Turbo jay's Avatar
    Leather repair specialist
    Jul 2012
    North west
    547
    thanks
    I,d say that's a fair price mate
  1. Replies: 7
    Last Post: 2nd May 2012, 22:30
  2. Just bought a3 2007 1.9tdi need help please on alloys
    By flyboy625 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th May 2011, 19:48
  3. hello im a newbie just bought this !
    By granny87 in forum The Welcome Section
    Last Post: 12th October 2009, 20:45
  4. Newbie just bought his first S3.
    By in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th May 2005, 10:56
  5. Hi newbie just bought an S3!
    By ianhg in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th January 2005, 08:06
