Chris NottJMB Retrofits
Results 1 to 16 of 16
    Aug 2010
    34
    S3 With MAYONNAISE
    Hi, Just noticed today what I think looks like a bit to much Mayonnaise in the oil filler cap. Just wondered what other peoples look like? I know there will be some and this is normal. Mine was covering the filler cap and some around the edge of the neck. Thanks in advance.
    2008 Phantom Black S3
    audicruiser's Avatar
    Audi Heaven
    Somerset
    1,861
    Quote Originally Posted by brads View Post
    Its the car saying stop using me for short journeys and get me on a run. It's common at this time of year due to the colder weather. A 30 miles fast run will clear it.
    Scott
    Audi A3 Sportback 2.0T Quattro S-Line 2007 8P2
    Lava Grey, Exclusive Line Black/Silver Leather, Heated Seats, Bose, RNS-e, iPod, Auto Lights & Wipers, Interior Light Pack
    PaulAr's Avatar
    S3 (8P)
    Mar 2008
    Tyne & Wear
    4,047
    I had mine off today as the oil needed a top up and it was clean.
    Car is MY12 and on 8K miles, does mostly short runs around town.
    I have seen this on previous cars and it wasnt an issue though. Its oil vapour and moisture condensing at the high point in the engines as it rises.
    If you had it on your dipstick then thats a different issue of course.
    Paul
    Now:
    -MK2 Golf Gti 16V/VR6, Oak Green, Shrick, Intake, Decat, Kish Retrim, Lenso BSX..
    -BMW 335d Xdrive, Estoril Blue, fully loaded.
    Before:
    S3 (8P), Ibis, DSG, Milltek, SHARK
    BMW 320d M Sport
    S3 (8P), Sprint, REVO, H&R Springs, BBS CHs,
    Golf MK5 GTi 20TFSI - REVO Stage1, Red.
    Golf MK5 GTi 20TFSI - Std, Shadow Blue
    Civic Type `R`
    Golf MK4 GTi 18T - 200bhp, MTM ECU, Forge DV
    Golf MK3 VR6 - Cat Back
    Corrado VR6 - JAMEX
    Corrado G60 - JAMEX, BRM Charger rebuild
    etc....
    Aug 2010
    34
    Hi thanks, yeah I have been doing short runs recently. Dipstick is clean, so hopefully sounds ok. Cheers
    Wicked666's Avatar
    Feb 2005
    Leeds
    582
    Bit of a hijack but how do you guys know when to top it up? I've always left my oil until the annual service but should I be checking regularly? Or would I know if it's running low somehow?
    Dec 2012
    236
    should always give it a good run now and again, although a small amount of oil "condensation" is no big deal, do what you can to keep it minimal
    PaulAr's Avatar
    S3 (8P)
    Mar 2008
    Tyne & Wear
    4,047
    Quote Originally Posted by Wicked666 View Post
    Its critical to check the dipstick every couple lof weeks as oil consumption can vary wildly between cars.
    It should never get so low that the warning light comes on.
    High revving stuff can need oil every week, HONDA VTechs etc are like this.
    I have topped mine up twice in 8K miles.
    Now:
    Before:
    BMW 320d M Sport
    Civic Type `R`
    Corrado VR6 - JAMEX
    etc....
    Dec 2012
    Hordnean, Hampshire
    157
    As said, it's normal to get some at this time of year. Give the cap and neck a good clean to remove the residue and then check it again after a long run, should remain clean. The fact your dipstick is okay should mean it's not so bad, if you can get a look at your coolant check to seee there's no thin oil film on it, clean coolant is also a good sign.
    Wicked666's Avatar
    Feb 2005
    Leeds
    582
    Quote Originally Posted by PaulAr View Post
    Thanks - what oil do you recommend? Shall I just pop to Audi and get what they use when they last serviced my car?
    PaulAr's Avatar
    S3 (8P)
    Mar 2008
    Tyne & Wear
    4,047
    Yep, ask AUDI what they used last time and pick 5ltrs up from a motor factors/Halfords etc..
    At least then you will always have it on hand.
    I am sure I read somewhere that if you are on a variable service regime and you run your oil levels low on a regular basis then the intervals are much reduced.
    Bad for the car, bad for the wallet..
    Paul
    Now:
    Before:
    BMW 320d M Sport
    Civic Type `R`
    Corrado VR6 - JAMEX
    etc....
    jaydav2306's Avatar
    Why is it bad if there is a tiny bit on the dip stick? I'm seeing this on mine and again only doing short runs I think I need to take her in a long run?
    2009/2010 | Audi S3 Black Edition Ibis White | Black Optics Pack | Fully Loaded | S-Tronic
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Happens.. Some attributed to poor quality engine oil.
    Try taking the oil filler cap off and letting the car run for 20 mins to get rid of moisture in the engine's internals.
    jaydav2306's Avatar
    It's definitely not poor quality oil so it must be the short runs I'm doing, only 10 miles a day at the moment
    PaulAr's Avatar
    S3 (8P)
    Mar 2008
    Tyne & Wear
    4,047
    I am doing 15miles-ish per day (2 short runs) no dip stick residue.
    Never seen this on modern cars.
    Now:
    Before:
    BMW 320d M Sport
    Civic Type `R`
    Corrado VR6 - JAMEX
    etc....
    Jan 2009
    330
    To the hijacker - I top up my oil every 2000 miles I use 1 ltr.
    Now: 2009 S3 8P3 DSG. Mods: Revo Stage 2+, TBE, Autotech HPFP, Revo CAI, Cruise control, LED interior lights upgrade, Rear DRLs...
    Previously: 2001 AMK S3, Silver, Revo Remap, Milltek DV, KW Springs & Shocks, H&R ARB.
    Pushing the limits..
    Jan 2011
    Australia
    1,307
    Add Sevv on Facebook
    mate personally i change mine every 6 months wether i done 5000km or only 2 -3000kms keeps the engine happy
  1. Logging turbo boost with VAG-COM
    By Ram in forum VCDS (formerly VAG-COM) forum
    Last Post: 26th January 2009, 22:23
  2. Anyone have any experience with Abt chips?
    By plampine in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 22nd July 2003, 22:36
  3. Whats ok to wash with on a re-srayed wing?
    By mramage in forum Other Brands & Models
    Last Post: 2nd February 2003, 16:55
  4. Problems with alarm transmitter.
    By DJG in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th January 2003, 08:23
