Results 1 to 10 of 10
    imported_ANNANBHOY
    Please Please Please Help
    Hi folks, Im taking my car back to my dealers again tomorrow regarding rattling windows and also the "knocking noise" from the rear suspension.
    They advised me that they are not aware of any problems and its already been in 3 times !
    could you please give me your experiences of any of these problems so I can print this off and show them.
    Many thanks
    Amchlolor's Avatar
    Jan 2005
    Aberdeen
    5,602
    Re: Please Please Please Help
    Bloody garages...
    Can you not ask to take a mechanic for a drive ?
    That's what I did about my rattle.
    They can hardly deny it happens when it's demonstrated to them in your presence.
    The Slug's Avatar
    Nov 2004
    UK
    1,853
    Blisters have a so called "quality control guy" who comes out for a test drive to see what the faults are etc.. But doesn't ****kkkin quality control the blooody mess the YTS kids leave in the car tho, fukkinn noobs, Sorry rant over
    JaminBen's Avatar
    Jan 2005
    France (ronRonrRRron)
    532
    I had a rattling window (near side) and rear dampers which mad a knocking noise. Both problems were fixed by my Audi dealer, as is to be expected.
    pm me if you need my full name, adress, and the service manager of my dealer.
    imported_ANNANBHOY
    thanks mate I will do if needed
    Halgernon's Avatar
    Aug 2005
    Essex, UK
    25
    [ QUOTE ]
    [/ QUOTE ]
    Not aware? I don't see how when there was an Audi response to the knocking rear suspensions struts... mine were replaced FOC.
    I went in with the car after three months saying about the knocking, they looked but couldn't find a fault. I thought it was just me, but a couple of weeks later they rang me up saying Audi had identified a possible fault and the rear suspension was to be replaced.
    They never did fix the sodding rattle on the passenger door though - it's been in several times for it, been greased, had new rubber strips - nothing stops it. I'm forced to listen to my iPod at exceptionally high volumes now... [img]/ubbthreads/images/graemlins/cool.gif[/img]
    Jul 2004
    S.E. Essex
    152
    Check out my threads & I'll tell you how to cure rattly windows - pretty much...
    Halgernon's Avatar
    Aug 2005
    Essex, UK
    25
    Thanks steveb - any and all help gratefully received!
    I did find this online seller for gummi-pflege mind you:
    http://www.knightsbrooke.co.uk/inter...d-exterior.htm
    If this is the carcinogenic rattle cure, I'll risk it and cure the rattle! The link through to payPal doesn't seem to work, but Worldpay does...
    imported_S_Line
    my rear shocks were replaced as well after rattling.
    When i phoned them to say, i need my rear shocks changed ( its very common) they said " Why"
    Cause loads of them rattle !!!
    Dealer said to me they havent had that problem before - Yeah Right !!!
    Jul 2004
    S.E. Essex
    152
    Make sure to spray the "groove" in the seal along the top of the door...
