EM TuningAH Fabrications
Results 1 to 16 of 16
    Sep 2012
    7
    Need help cannot code bluetooth for RNS-E
    Hi All,this is my first Audi. Im trying to install the bluetooth module for my Audi A3 2004 Quattro I have installed the RNS-E headunit got a Bose system also I have installed the bluetooth unit.
    however I'm trying to do the coding part and when im trying to do the RNS-E coding I cannot select the
    Option 5 - Telematic Europa.
    Could someone guide me on what I'm doing wrong.any help would be appreciated thanks
    27,113
    Please show a log of modules 37 & 77.
    2,175
    Try option 7 Base Plate .........
    Sep 2012
    7
    Thanks B5NUT for that I have tried option 7 and now comes up with message " your telephone may not be connected or attached properly"
    Also when I started my car I started the RNS unit and immediately started searching for the Bluetooth.I think for a second there it picked up the Bluetooth on the scan device and it disappeared soon after.
    Sometimes also it just say " telephone not available"
    any suggestions...
    27,113
    Where's the log requested please.
    Sep 2012
    7
    Hi NHN, Sorry I'm literally new to this. im a beginner in this and Ive got the VCDS recently only for the bluetooth .would you show me how do I do this I have taken screen shots of the navigation at the beginning before carry out any changes Ive attached the screen print of the navigation the telephone I have only tried to change to 5 but no luck same from previous post
    Jan 2012
    1,837
    looks like you're using a non genuine cable?
    11.11.5 has just been released and you're on 10.6
    27,113
    I need a log of the modules on the car, thats just a screen dump of the module coding screens, use autoscan to get a log of the car & post up modules 37 & 77 FULL results.
    For the record, this forum does not support counterfeit vcds cables, if it is indeed non genuine, then I can help no further I'm afraid.
    Sep 2012
    7
    How do I get the log
    Jan 2012
    1,837
    main vcds screen, press autoscan, from the drop down menu on the left hand side select "detect automatically" then let the car do its thing and then copy the results into a reply
    Sep 2012
    7
    Yes got it as im on a budget
    27,113
    Quote Originally Posted by strykerz View Post
    Meaning its counterfeit?
    Sep 2012
    7
    I'm not sure ? as I bought this on ebay. Ive just had one of the mechanics come over now and he has used his cable done the changes and has now fixed the issue and is working thanks.
    Jan 2012
    1,837
    How much was your cable? Genuine second hand ones usually go for £200+
    Sep 2012
    7
    this one was 80
    27,113
    Fake.
  1. Bluetooth for RNS-E
    By Paul100 in forum In-Car Entertainment
    Last Post: 2nd January 2012, 17:38
  2. New here and need help with codes.
    By 98Quattro in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 12th October 2008, 23:43
  3. need help fault code
    By audi-90qua in forum Classic Audi Forum
    Last Post: 28th October 2007, 12:22
  4. Engine swap - need help with codes
    By Pincher in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th August 2004, 22:33
