Sky InsuranceVolks Autos
Results 1 to 9 of 9
    Dec 2012
    13
    Car getting stuck in 1st gear.. help appreciated
    Hi guys,
    New to this forum, so hope you guys can help!
    I have an Audi A3 2.0tdi 6spd
    Recently, but only occasionally, the car will get stuck in 1st gear - e.g. If i'm at lights, I will press clutch and put it into 1st whilst waiting. Then after a few seconds (the time differs each time it happens) the revs will kick up ever so slightly, and then I cant get it out of 1st. I have to let go of the clutch so the car rolls a tiny bit, re press the clutch and then I can take it out..
    What could this be? The car being an Audi is probably irrelevant as I suppose this does happen to others..
    (I haven't tried any transmission fluid as yet - I need to get some)
    Hopefully its nothing major. the car generally goes into all gears perfectly fine, clutch doesnt slip either.
    any help appreciated!!
    Gurdeep
    Apr 2012
    London
    463
    Welcome to the forum mate,
    I had similar sort of problem but not as much as what u r saying...
    Basically mine wasn't shiffiting gear form 2nd gear to 3rd only, basicall I had to run it on high rev as 4/5 to be able to shift gear, and didn't have anything to do with gear, clutch and so on, not sure what it was but will ask my local garage to see and will let you know by Monday!
    Have a look around and get different quotes from several dealers to get it fixed...
    By the way don't u have warranty?!?
    Dec 2012
    13
    Hi mate. Thanks for the welcome
    See mine only gets stuck in 1st.. all other gears are fine. Im gonna phone my garage as well and see what they say!
    Cheers - itll be good to see what your guys think too!
    I bought the car from a 2nd hand car dealer, but my 6month warranty has expired now... typical lol
    Apr 2012
    London
    463
    You're welcome;
    I called them on morning and no one picked the phone, so popped there just about an hour ago and its closed till Wednesday, so will give it a try on wed and see what they say;
    To be honest to get mine fixed by that time, I had different quotes, from 600 to 800 pounds, but these guys offered 245! That's why I'm saying better to try several places before considering it done...
    Anyway will get you posted on Wed!
    Cheers and happy new year
    Dec 2012
    13
    hi,
    anyone else shine a bit of light on this?
    Really starting to bug me. I've done searches online but cant seem to find anything that relates to it...
    sliced's Avatar
    Drive safe, stay alive.
    Jun 2012
    1,162
    Hi mate, has the clutch been changed on the car at all?
    Sounds like the cables for the gearbox are bad?! ( not the gear linkages cables)
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    In The Sticks....
    2,625
    So if your in neutral i.e idle, whats the revs at? (once at running temp)
    Sounds to me it could be set a little high thats all.
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    Dec 2012
    13
    Hi
    As far as I am aware, it hasn't been changed..
    I have found this on pistonheads forum... a guy who has the same issue has me seems to have found a solution...(hopefully can help others)
    audi a3 2.0 tdi DOESNT ALWAYS LIKE GOING IN GEAR! - PistonHeads
    Just waiting for the snow to stop before I go out and give it a go!!
    Oct 2012
    Fife
    59
  1. Help, gearbox stuck in two gears which codes please?
    By Dj0gt0 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th December 2012, 20:46
  2. Car Judder accelerating from 1st to 2nd gear
    By Spidey99 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 19th October 2011, 09:50
  3. HELP APPRECIATED, DIMENSIONS OR ALL IN CAR SPEAKERS NEED ?
    By ashleyhutchinson43 in forum In-Car Entertainment
    Last Post: 13th August 2011, 14:11
  4. New A4 owner with a few small car problems.Any help appreciated
    By mike-a in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th November 2010, 22:59
  5. Audi A4 1996 TDI 1st gear problem :( Help !!!!!
    By slips in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th October 2004, 22:15
