Chris NottMonster Motorsport
Results 1 to 13 of 13
Like Tree1Likes
  • 1 Post By Sidhu88
Thread: Anyone had heater issues on tdi 170 SB ?
    Baza1819's Avatar
    Jan 2012
    Sunderland
    254
    Only just realised my heaters are next to none existent, blowers are working fine but the heat side of the system is pathetic ??? Any help would be appreciated..........
    2.0 tdi 220 Quattro.....
    Bigfish tuning remap, S-line half Leather heated seats, Bose sounds, Elec' fold in heated mirrors, tyre pressure monitors, Charcoal roof linning, Mfsw,phone prep, 18" Speedlines, Dual climate, total open/closure remote windows,L.e.d rear lights, Ch/Lh lights,puddle lights,Cruise Ctrl, Ambient Interior lighting, footwell lights & it's a Quattro......
    Baza1819's Avatar
    Jan 2012
    Sunderland
    254
    Quote Originally Posted by Baza1819 View Post
    Had a full vancom scan > all clear ?????
    Jul 2012
    tuxford nottinghamshire
    48
    Could it be your heater matrix? I had the opposite problem to you I could get heat but the car wouldn't blow and circulate the air around the car, puzzled me for a day or so turned out it was the motor had seized.
    Baza1819's Avatar
    Jan 2012
    Sunderland
    254
    Was that expensive to sort m8 ????
    Jul 2012
    48
    No dude I just took it off and greased it up, I believe that the heater matrix is fairly expensive.
    Baza1819's Avatar
    Jan 2012
    Sunderland
    254
    Is it under bonnet or behind dash ??
    Av changed pollen filter ( which was filthy ) am getting a bit ov heat now but still not as it shud be !
    Will try that next
    Jul 2012
    48
    It is behind the dash where the glovebox is. from what I remember there are about 7 screws and they are something like 7-8-9mm and then that will reveal your motor when it is taken out. Then you just need to turn the bottom of that anti clockwise and the resistor and motor both come out together there is some stuff that needs unplugging but that's not hard.
    Baza1819's Avatar
    Jan 2012
    Sunderland
    254
    Nice 1, cheers Cookie !!
    Jan 2012
    SW London
    794
    Have u checked ur coolant levels? Are u running proper coolant and not a weak watered down solution?
    Baza1819 likes this.
    2006 Audi A3 2.0 TDI S-Line 8P2 PD170 - Dolphin Grey Metallic - The problem child
    1994 VW Golf VR6 - Mystic Blue - The money thief
    VCDS User
    Baza1819's Avatar
    Jan 2012
    Sunderland
    254
    No idea tbh, but i'll try that 1st.
    Baza1819's Avatar
    Jan 2012
    Sunderland
    254
    Cheers sidhu88 for that info !
    Jan 2012
    SW London
    794
    Any luck?
    VCDS User
    Baza1819's Avatar
    Jan 2012
    Sunderland
    254
    Not had a chance to check it yet > hopefully get it done 2moro m8
  1. Has anyone had DPF issues as result of a remap?
    By Cossie_boy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th February 2013, 13:41
  2. Replies: 97
    Last Post: 16th October 2012, 18:13
  3. 170 TDi - anyone had turbo issues? if so what were your symptoms pleeeeeease?!
    Last Post: 14th August 2012, 23:22
  4. Has anyone had a MY 2012 TDI remapped
    By h5djr in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th October 2011, 19:45
  5. R32 ARB's. Anyone had any issues?
    By 20valver in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th October 2006, 10:19
