Chris NottAH Fabrications
    Feb 2004
    Borders, Scotland
    404
    Question TDI quattro suspension.
    I have a broken front spring and the car's due an MOT soon so going to have to do something about it. Does anyone know how muc lower than standard, sports suspension is? Basically I am not unhappy with the ride or height, maybe would go a bit lower but not much and I am thinking I might be better just getting a set of lowering springs. What would be your recommendations; new OEM springs, Lowering springs, something else? Cheers.
    May 2008
    222
    im sure the sport is 15mm lower than the SE, and the s line is 25mm lower than the SE, but im sure someone will be over to correct me if im wrong.
    Feb 2004
    Borders, Scotland
    404
    You may guess I ahve been here before with Golfs, you see something that's 35mm lower but that's 35mm less than standard and yours may already be close to that. I had Eibachs on my Golf but was a bit disappointed when one broke after only a few thousand miles. Did get a warranty replacement but still a bit disappointed.
  1. 3.0 TDI Quattro suspension problems
    By Gixser07 in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 24th November 2012, 17:46
  2. 1996 A6 2.5 Tdi Quattro Estate Glow plug problem
    By mmarks in forum Diesel forum
    Last Post: 4th December 2003, 19:54
  3. 2.5 TDi Quattro hopeful speculation?
    By bsharp in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd November 2003, 13:01
  4. Turbo noise - 1997 1.9 Tdi Quattro
    By Holywood in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th August 2003, 15:36
  5. 1997 A4 1.9 Tdi Quattro - turbo noise
    By Holywood in forum The Welcome Section
    Last Post: 26th August 2003, 15:10
