Chris NottMonster Motorsport
Results 1 to 13 of 13
    Feb 2011
    44
    Audi S3 8P rackety/tappet/diesel sound on idle
    Hi guys!
    8P S3 only on idle sounds like a diesel very tapperty and rattley etc, ain't coming from the engine to the best of my knowledge I think maybe from the Cambelt aera? Potentialy could be water pump or the cam belt the tensioner?
    Cambelt was done 7K ago..
    Car boosts more than fine and idle is smooth!
    Just abit worried everytime I get out the car and hear the devil noise lol!
    Whats your thoughts?!
    Thanks in advance
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    4,791
    You're sure it's not just injector noise.....direct injection engines can sound somewhat diesel like at idle.
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,071
    I asked a similar question when I bought mine, a bit diesel sounding at idle. It's all good :-)
    A3 Sportback 2.0 TFSI S-Line Quattro Stage 1 Tune it up - Lowestoft Custom Remap- 6187 RPM developing 260 bhp 279lbs ft Akoya Silver, Roof rails, Black heated Vienna Leather, Bose upgrade, Bluetooth
    Jan 2009
    192
    Yeah, sounds normal to me.
    Now: 2009 S3 8P3 DSG. Mods: Revo Stage 1, Cruise control, LED interior lights upgrade, Rear DRLs...
    Previously: 2001 AMK S3, Silver, Revo Remap, Milltek DV, KW Springs & Shocks, H&R ARB.
    Dec 2008
    Georges Hall NSW Australia
    29
    I'd be having a look at the Fuel pump cam bucket....
    Len
    Feb 2011
    44
    whats cam bucket len?
    2011 Audi S3, Two Tone Leather, Rotar Arm Alloys, RNS-E.
    Nov 2012
    Dorridge, Solihull
    25
    If you can hear the diesel type sound inside of the cabin it will be your camshaft tensioner, chain and adjuster most likely. These are part of the timing service but it gets over looked as a lot do not realise there is one.
    I have just done mine and it cost me £390 with a fuel pump follower and oil and filter including buying the tool to lock the cams in place but expect to pay over £1000 at a specialist and even more at a dealer.
    If you need any more info let me know ;-), but its mainly caused from the rubbish dealer service schedule and poor quality oil they use!
    Regards
    John
    Feb 2011
    44
    Hi mate, from cockpit all sounds normal just when your outside of it! So what does that entail...
    Just done a service used 35/5 castrol magnatex..
    Did a long drive 20omiles was booting it and still when I reached my destination wasn't any louder...
    Nov 2012
    Dorridge, Solihull
    25
    Best thing I can suggest is get a long screwdriver and place it onto the metal plate under the side of the engine cover, gearbox side and if you can hear a rattle from there that's where the camshaft chain is situated and that's the culprit bud. I'm on my iPhone at the moment but when I get to my laptop I will pm you some info so you can check but I came from a MK5 Golf Gti so I know how these Tfsi lumps should sound but I was not too bothered with doing this job on my S3 as I bought through the trade real cheap ;-)!
    Feb 2011
    44
    Like the tensioner..? Yes that will be fine mate just pm all the details, I'll have a look at it! Just that sound I don't like it lol as you probably wouldn't ))
    Nov 2012
    Dorridge, Solihull
    25
    No problem I will also post some pictures of the parts I replaced to show the wear on the tensioner guides from the poor oil and service schedule. The oil your using is better but I have swapped to 10w40 VAG specific 502/505 an that helped quieten things down too.
    If it is the rattle like I had it will be a worn tensioner/stretched chain and cause the chain to rattle when the oil thins out at temperature as you will not hear it on cold start, under load but it will become present when not under load as the oil pressure will be reduced as that is what helps keep the tensioner under load I'll explain more in my PM bud ;-)
    Regards
    John
    thebambam's Avatar
    P.I.M.P
    Dec 2011
    Gutersloh Germany
    65
    Follow thebambam On Twitter
    Yeah same problem was diagnosed as my tensioner. Rattly thing will be getting done with the cambelt etc in 2 weeks woop
    Jan 2013
    Quote Originally Posted by JMB-S3 View Post
    Regards
    John
    Hi
    I have just bought a 57 plate s3 with 60000 miles sounds like i have this same problem could you send me the pm as well? Many thanks
  1. audi a6 1.9 tdi diesel 130 sport avant
    By hoddy8770 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 25th March 2011, 19:55
  2. audi a6 1.9 tdi diesel 130 sport avant
    Last Post: 10th March 2011, 13:49
  3. Which Audi is best for me? diesel or petrol?
    By myVAG in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th October 2010, 20:24
