EM TuningVolks Autos
    Nov 2012
    47
    Post IMF REMOVAL HELP
    hi im trying to remove and replace the inlet manifold on my car. just wanted to know which tools will i need and what tool opens the 3 bolts on the actual IMF? All help will be appreciated. If there is anything i need to make special note of please mention as well.
    Nov 2012
    47
    Ok managed to get the egr valve and IMF removed. Have a look at the gunk inside the egr valve
  1. lower dash removal help
    By bigblokey0 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 19th November 2006, 23:03
  2. side indicator removal...(help please)
    By Vikz in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th July 2006, 09:41
  3. A6 - Headlamp Removal ??? Help
    By imported_bobbinz in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 29th September 2005, 18:25
  4. Rear Side Window Removal help (3 Door)
    By Rallyman in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th July 2005, 21:05
  5. A4 B6 door panel removal - help!
    By imported_Pottsy in forum In-Car Entertainment
    Last Post: 24th October 2004, 17:29
