Monster MotorsportChris Nott
    Dec 2012
    24
    Order of tuning for an S3?
    Ok,
    Just want to know what the correct order of tuning is for the S3, I presume exhaust and filter to start, then remap, but at what stage do you need a fuel pump and when does the clutch start to slip?
    monopole's Avatar
    limboitis
    Oct 2012
    County Antrim
    296
    Your clearly looking at stage 2+, cos for stage 1, just map it and thats it for 305-310 bhp (265 TFSI)
    +incoming (64/Sep 1st) S3 (300) Sportback S-Tronic Quattro Daytona Grey
    -outgoing (63) A5 2.0TDI (177) Coupe Black Edition S-Tronic Quattro Phantom Black
    VCDS Location: NI (County Antrim)
    - (62) A1 1.6TDI (105) Sport Manual Sportback Brilliant Black
    - (62) S3 (265) Sportback Black Edition S-Tronic Quattro Phantom Black
    - (58) TT Roadster 3.2 V6 (250) S-Tronic Quattro Phantom Black
    Aug 2009
    Kent
    70
    I would say map first as the exhaust and filter will help the map.
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,322
    Quote Originally Posted by Mark300zx View Post
    Ok, Just want to know what the correct order of tuning is for the S3, I presume exhaust and filter to start, then remap, but at what stage do you need a fuel pump and when does the clutch start to slip?
    You need an upgraded HPFP for Stg2+ or above(which is approximately 360bhp),and the clutch will start to give up at anywhere from Stg1 on,depending on whether you're lucky or not.
    I think the rule is that when you start remapping the S3,you should budget for a clutch upgrade from the start,as it will go at some stage.
    The HPFP upgrade smooths out the midrange torque dip that would otherwise occur,and whilst it doesn't add a huge amount of power,the effect in terms of delivery and torque is very noticeable.
    Nathan_jones2002's Avatar
    V8 - only sound a man needs
    Dec 2012
    North west
    280
    If you have the S tronic then you won't need to upgrade the clutch/flywheel at stage 3.
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,322
    Quote Originally Posted by Nathan_jones2002 View Post
    If you have the S-Tronic,it will be OK up to around 440lbs assuming the correct software is used,but at the upper levels of Stg3,you will need to upgrade the clutch plates,and HPA Motorsport offer the correct parts for this.
    Stg3 in most tuner's books is a big turbo kit,and whilst you can easily limit boost to below 1.7bar,and keep torque down,it kind of defeats the object of a BT kit to do so,and thus most of us running BT kits on DSG/STronic cars would say that a clutch internals upgrade should be factored into and Stg3 or Stg4 builds.
  1. Best Chip / Re-Tune for a 130bhp Sport A4
    By sc00byd00byd00 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th February 2006, 17:19
  2. It's ordered just waiting for a build date
    By Anito in forum General Chat
    Last Post: 11th November 2005, 12:58
  3. ECS Tuning for A4/S4
    By RichA3Turbo in forum A4/S4 forum(B5 Chassis)
    Last Post: 31st March 2005, 19:14
  4. ECS Tuning for A4/S4
    By RichA3Turbo in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 31st March 2005, 16:35
  5. Who does the most reliable tuning for a 130pd
    By 18ME in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd November 2003, 16:52
