EM TuningChris Nott
Results 1 to 9 of 9
    Jul 2012
    Essex
    183
    Help,Removing side light bulbs.
    The front ones. Do they pull straight out or are they on a bayonet type holder? tried twisting both ways and pulling but to no avail.
    Help
    Nov 2012
    Belfast
    23
    They are the fiddliest things to do but just give them a wee tug if you can get a good grip on the wires and they should just pull straight out
    Oct 2012
    492
    Done mine last week mate take off the door on back of headlight remove main beam bulb and pull holder out of the way now get a pair of long nose pliers and get a grip of the sidelight holder and give a little turn up and down first you haven't got much room but you can just get a bit of movement on it now grip it and pull it out levering on the edge of the opening that did the trick for me hope this helps you mate I tried all sorts first and took some skin off my hands but once I had done it this way the opposite side was changed in 2 mins no probe, good luck mate
    TimG's Avatar
    Feb 2004
    South Coast
    932
    Tip of a sharp knife to prise them out worked for me.
    May 2012
    West Country
    172
    I'd say long nosed pliers as well, same type of holder
    as on the fabia I reckon Bernie. Can't check on mine, I don't have sidelights mate.
    2009 S3 3 door. Phantom Black metallic.
    RNS-E, Tints, Piano Black inlays, Auto Lights and Wipers, Bluetooth, MFBSW,
    White Alcantara, LED numberplate lights, Black Optic Grille, Yellow Foglamps,
    K&N panelfilter, Colourmatched mirrors, S3 footplate,
    More to come....
    Jul 2012
    Essex
    183
    Got them out now by Southylads method.
    Thanks for all the replies fellas.
    Oct 2012
    492
    Glad it helped mate it had me stumped for a while on the first one I thought they were never gonna come out but once I got that out with the pliers the other side flew out cheers
    Jul 2012
    Essex
    183
    My mits are too big so give my Pit Crew instructions and with a bit of twisting and wiggling he got them out.
    Oct 2012
    492
    I did take a bit of bark of my hands myself on the first one there is very limited space eh mate
  1. Help changing side light bulbs w5w
    By afcjay in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st September 2012, 09:48
  2. Side light bulbs on A3 SPORTBACK
    By grey99 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th August 2006, 18:54
  3. Help Reuired - Side repeater bulbs
    By Stepho in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th August 2005, 12:14
  4. how to remove side light bulbs?
    By jediknight in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th December 2004, 13:04
  5. New A3 Side Light Bulb Change
    By garethj in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th February 2004, 21:01
