Chris NottSky Insurance
Results 1 to 13 of 13
    Oct 2012
    492
    put egr blank in and not getting warning light?
    as title says i just installed my egr blank plate , i expected to get a warning light up on dash to warn its not workig but nothing?
    i put the blank plate inbetween the thinner silver pipe and the egr on right hand side is this correct?
    any ideas why the dash ight has not come on as i have the car booked in for remap and egr light and software mapped out but its not on? any advice would be great.
    ok the pics is on its side so pipe i put it on is at the top of pic.
    Oct 2006
    Malvern
    51
    When i was trying to find a stutter on my BKD, I blocked the hose feeding the EGR valve using a golf tee. The car drove so much smoother, and no fault came until a coolish damp morning.
    Everyday:
    Audi A4 3.0 TDI quattro - 2008, Panther Black
    Upgrades: Planning in progress !!!
    Weekends:
    Audi ur quattro - 1989 (was 2.2 5cyl turbo, currently evolving to 3.6 V8 twin turbo!)
    Registered VAGCOM user.
    Oct 2012
    492
    Quote Originally Posted by A_C4mby View Post
    which one the little black hose is that a vacume hose does that operate a diafram to open and close the egr is it as simple as takeing that of and blanking that? the car seems to idle a lot smoother already yeh
    Oct 2006
    Malvern
    51
    Yep, it's just a vacuum pipe connected to a diaphragm. A spring holds the valve shut, then the vacuum opens the valve.
    Everyday:
    Weekends:
    Jan 2012
    478
    It might take a while for it to appear - too a couple of days on my old diesel.
    Oct 2012
    492
    Management light now on came on this morning
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,079
    Quote Originally Posted by southylad View Post
    Southylad, pleased to report no clutch slip after the map and damn it goes some now! Sorry wrong thread being lazzzzzyyyyy
    A3 Sportback 2.0 TFSI S-Line Quattro Stage 1 Tune it up - Lowestoft Custom Remap- 6187 RPM developing 260 bhp 279lbs ft Akoya Silver, Roof rails, Black heated Vienna Leather, Bose upgrade, Bluetooth
    Oct 2012
    492
    Remap
    Quote Originally Posted by JamesO View Post
    Hey glad to here that mate bet it was a good drive home eh , can't wait to get mine done now mate bet it puts a smile on your face every time you touch the peddle eh
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    Re: put egr blank in and not getting warning light?
    Southylad, would you be able to mark on the photo where to fit the blanking plate? Looks like this will be my next mod.
    VCDS USER
    Oct 2012
    492
    Blank plate
    Quote Originally Posted by SAiLO View Post
    Can't seem to do it in editing mate but will try and explain for a start the pic has been flipped so the top is in fact the right hand side so you see the silver pipe with the oval flange and 2 hex bolts holding it at top of pic you just undo the 2 hex bolts ease the flange away from the egr body and slip you blank in and replace the hex bolts it is an easy job the plates are only couple of quid of eBay then you have to have the egr mapped out if you don't want the eng man light on all the time
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    Thanks mate!
    That was my guess but wanted a confirmation.
    I'm gonna go for this part:
    028 131 547 B which has a small hole drilled that prevents the EGR light coming on.
    VCDS USER
    Oct 2012
    492
    Yeh I looked at them aswel mate
    Aug 2009
    Kent
    70
    The light will and did come on after the EGR delete mod untill the Map is changed.
  1. where to put egr blanks
    By southylad in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th December 2012, 17:36
  2. Just bled the brake fluid and replaced...Brake warning lights!!
    By Fahim in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 17th December 2010, 01:05
  3. Changed all brake pads and still getting warning on dash on 2.8Q
    By AndyMac in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th April 2010, 22:49
  4. Frozen Door and Air Bag Warning light
    By A Rowley in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th January 2010, 22:55
  5. EPC and eng managment warning lights help!!
    By HAWKEYE in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th June 2009, 01:04
