EM TuningVolks Autos
    Oct 2012
    Leicestershire
    17
    Strange stuttering while coasting. advice needed please
    Hi all,
    Fairly new TDI s-line owner here and I'm loving looking through this forum.
    Spotted a potential issue last night and as the title says when coasting in neutral the car runs fine but as soon as I apply a little brake the idle starts jumping around like a miss fire. Anybody had this before or can shed any light on it?
    Cheers all..
    Sportback owner
    Apr 2007
    France
    465
    Never had this Bertie, but here is a suggestion. On the TDI, vacuum for the brakes and other needs is supplied from the tandem pump, driven off the inlet camshaft. It is called a tandem pump, since the unit is combined with a fuel pump. Anyway, as far as I know this pump supplies the brake system, but also provides vacuum for the exhaust gas recirculation (EGR) system as well. It may supply vacuum to other engine management devices too. I am sure other members will be along to comment more on this. Anyway, I suggest you might like to get a mechanic to go over all of the vacuum pipes and connections. That is the only definite link I know between the braking system and the engine management. Good luck.
    French A3 Sportback 2006, 2.0L 140 TDI, DSG, RSN-E, Ambient lighting, Auto-lights/wipers, Reverse assist, Dolphin Grey, 17" wheels, Leather seats, Cruise control, Roof bars.
    Oct 2012
    Leicestershire
    17
    thanks for the info Gerald. can anybody else confirm Gerald's thoughts or point me any other direction?
    Sportback owner
    Apr 2007
    France
    465
    Bertie, I forgot to add, that it would be a good idea to have the car scanned (VCDS) to see if any fault code had been thrown up. If so, that would help to diagnose which area needs looking at.
  1. new member/s3 advice needed please!
    By cookiedudeuk in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th November 2007, 16:40
  2. advice needed please
    By andy-exige in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th June 2007, 17:02
  3. advice needed please
    By theitalian3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th December 2006, 12:39
  4. Advice needed please
    By Herby1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th November 2006, 11:04
  5. Urgent Advice Needed Please with my Audi S3
    By lUCKYS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th August 2006, 12:53
