Results 1 to 12 of 12
Like Tree2Likes
  • 1 Post By monopole
Thread: TTS Engine cover
    monopole's Avatar
    limboitis
    Oct 2012
    County Antrim
    286
    TTS Engine cover
    I neeeeeeeeeeeeed one
    Question. On removing the oem turbo intake hose, would you normally see it oil soaked inside?
    IceHanger likes this.
    +incoming (64/Sep 1st) S3 (300) Sportback S-Tronic Quattro Daytona Grey
    -outgoing (63) A5 2.0TDI (177) Coupe Black Edition S-Tronic Quattro Phantom Black
    VCDS Location: NI (County Antrim)
    - (62) A1 1.6TDI (105) Sport Manual Sportback Brilliant Black
    - (62) S3 (265) Sportback Black Edition S-Tronic Quattro Phantom Black
    - (58) TT Roadster 3.2 V6 (250) S-Tronic Quattro Phantom Black
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,815
    Get one - not expensive and its easy to fit.
    You have to buy the two locating bolts for the TT though. I have the parts listed in my thread which I will dig up now for you.
    You should see some oil, have you noticed the level of oil drop much or having to add oil more recently?
    Boydie's Avatar
    Boycie
    Dec 2006
    4,815
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    Worcestershire
    2,785
    I asked the exact same question about the presence of oil earlier on in the year, and was told it was normal.
    However mine wasn't that oily. I just had a bit on the top rim of the inlet.
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    monopole's Avatar
    limboitis
    Oct 2012
    County Antrim
    286
    Im making the assumption they use oil to aid assembly of the parts, as a bit of oil there, wont affect the turbo. A bugger to pull off, so pretty snug fit.
    Oct 2012
    Cyprus
    30
    If it's anything like my Astra VXR then there is a crankcase breather fed into the inlet pipework. This takes oil vapour into the inlet causing the oil you see. If there's loads of it there could be slightly too much crankcase pressure (too much/wrong grade of oil?) but it's deffo not anything to worry about.
    monopole's Avatar
    limboitis
    Oct 2012
    County Antrim
    286
    Before......
    aaaand after....
    It came with the correct front x1 and rear x2 legs and fits like a dream
    Ordered an S badge off the bay, stuck it on and now the engine bay doesnt look like a bag of old spanners any more
    Dec 2011
    230
    Looks loads better with the TT cover
    Dec 2012
    Hordnean, Hampshire
    157
    Looking good
    Does anyone make them with the centre section in carbon, that would finish it off.
    As above on the oil, normal due to crankcase breather which is fed back into the intake pipework for reduced emissions, on older cars they used to vent to air.
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,122
    looks smart mate way better than it did do before good work
    off the road boohoo anyone got a gearbox for me lol!!
    Nov 2012
    Dorridge, Solihull
    25
    How much are the TTS engine covers new?
    Regards
    John
    JPK
    May 2012
    278
  1. TTS Engine cover for S3
    By poli84 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th May 2013, 09:38
  2. TTS engine cover.
    By CornRattle in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th July 2012, 13:35
  3. TTS Engine Cover
    By Silky-S3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th March 2012, 23:09
  4. Part number for TTs Engine Cover for use on S3 with Intake ?
    By Spin140 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th February 2012, 18:37
  5. TTS Engine Cover - Does it fit with ITG etc ?
    Last Post: 15th December 2011, 13:37
