Results 1 to 7 of 7
    May 2008
    214
    Audi A3 8P 05 - Factory Fit Xenons - Changing To Bi Xenons?
    Right, so im currently in the process of buying a salvage a3 which has factory fit xenons. Being salvage one of the headlamps is ok, other not so good, bit out of shape and would need changing.
    The cost difference between me buying bi xenons and a normal xenon is next to nothing.. But what would I need to make the additional feature work? Is there sensors to operate the left and right movement, or is it based on the steering?
    Are the ballasts bulbs etc the same?
    Any info would be highly appreciated.
    a3_sline_tdi's Avatar
    Aug 2009
    903
    Are you sure which headlights the car currently has? Single or bi-xenon? Which either one it has it will have levellers and washers, if its single xenon then you will still need adapters which will need to be connected to your central electrics if you have the right one for the DRLS and bi-xenon shutter.
    Current
    2006 56 A3 S Line 2.0 TFSI Special Edition Moro Blue
    previous
    2007 A3 S Line 2.0 TDI 170 S-tronic phantom black
    2006 VW Golf Gti Black
    2008 S3 Dolphin Grey
    2007 A3 S Line 2.0 TFSI S-Tronic Ibis White
    2005 A3 S Line 2.0 TDI S-tronic Brilliant Red
    May 2008
    214
    Quote Originally Posted by a3_sline_tdi View Post
    At the moment the car has single xenon, 110% no bi xenon.
    Which adaptors are these and where do they go?
    I also have access to VCDS
    May 2008
    214
    Bump
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,117
    PM NHN for an install.
    "Will these wheel fit my car PM's will not be replied to, do you research & use the SEARCH button"
    Detailing - Wheel Refurbishment - Shark Performance Software - VagbremTechnic Dealer - OEM Retrofitting - Remus - V-Maxx - Goodridge
    Aug 2009
    903
    Kufatec adapters from there website these are around £50, then they need wiring to your central electrics inside your car for the DRLS and xenon shutter but that's if you have the right module. You would need to check this on VCDS and see if you do.If you have then once there connected in then it's a matter of coding job done. Where are you based as I could do this for you??
    Current
    previous
    May 2008
    214
    Thanks for the advise so far, im just outside lichfield west midlands.
  1. Fitting Bi-Xenons to 8P1 with Factory fit Xenons? Possible? How!?
    By Joe90k in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th March 2013, 21:35
  2. Factory fit xenons, does it come with washers as standard?
    By p1tse in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 31st May 2011, 10:50
  3. Factory Fitted Xenon Performance
    By JohnboyC in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th January 2008, 02:35
