Volks AutosMonster Motorsport
Results 1 to 8 of 8
    May 2012
    Norfolk
    118
    2004 Audi A3 2.0 TDi Sport non start advice needed
    Hi i have an Audi A3 2004 2.0 TDi sport 89000 FSH
    The car was driving along and ignition lights came on and stopped and would not restart i have checked whats below so far.
    The electronic stabilization light shows up when trying to start engine the engine turns over fine and does not even try to fire or cough
    Vagcom scan showed
    17055/P0671/001649 - Cylinder 1 Glow Plug Circuit (Q10): Electrical Fault
    17057/P0673/001651 - Cylinder 3 Glow Plug Circuit (Q12): Electrical Fault
    I myself cant see the above causing it not to start but would affect cold start
    Checked fuel feed to pump when ignition turned on fuel going to filter fine
    Checked fuel coming out of filter all fine
    Checked fuel returning to filter all fine
    Tried spare key
    Removed diesel filter and checked for particles none present diesel clean
    Checked all fuses under bonnet and in car
    Battery fully charged
    Checked cambelt
    Im now thinking possibly high pressure pump
    any advice welcome
    Thanks in advance
    Marty
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    683
    Sounds like the dreaded injector failure, give Audi UK & they will get it in to your nearest dealer & repair it FOC.
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted!
    Bits for sale...
    Genuine S-line 18" alloys, A3 Sportback rear lights. A3 5dr window switches & mirror switch. , Brand new PD170 engine cover. PM for details.
    max69vk's Avatar
    Apr 2012
    683
    *Give Audi UK a call.
    Bits for sale...
    May 2012
    Norfolk
    118
    will they honor that on a 2004 car ?
    May 2008
    214
    I thought the injector issues where on 170bhp cars, yours being a 2004 I would say is the 140 BKD engine.
    May 2012
    Norfolk
    118
    Re: 2004 Audi A3 2.0 TDi Sport non start advice needed
    It either has to be injectors or pump I'm thinking as anything electrical I would of thought should show on vagcom. But I would of thought if pump had gone there would be some debris somewhere. So not sure what way to turn and don't really want to have to put in dealers if I can help it.
    max69vk's Avatar
    Apr 2012
    683
    Apologies I thought this was a PD170, either way those codes tend to relate to the injectors or loom, not the glow plugs as it says on the scan. Check that the multi plug connection on the side of the head is fully secured & not corroded, if all appears ok it may be worth removing the cam cover & checking the wiring is ok in there.
    Bits for sale...
    May 2012
    Norfolk
    118
    I had the multi plug of cleaned and checked.
    I have also taken the rocker cover of all wires intact. Next I will do a continuity test on all the wires to make sure they are complete.
    Forgot to mention that in my first post.
    If that shows nothing will have to be main stealer
  1. 2004 Audi A3 2.0 TDi Sport - FASH, BOSE, LEATHER.
    By Sheikh in forum For Sale/Wanted - Audi Cars
    Last Post: 1st August 2012, 14:48
  2. 2004 Audi A3 2.0 TDi Sport - FASH, BOSE, LEATHER.
    Last Post: 16th May 2012, 13:28
  3. AUDI, A3 1.9 TDI SPORT, BLUE, 2004, 55MPG, EW, RCL, CD, FSH
    By Joni_s in forum For Sale/Wanted - Audi Cars
    Last Post: 11th January 2012, 18:26
  4. AUDI A3 2.0 TDI SPORT 2004 ....STILL WONT START!!!!
    By jonboy04 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th August 2010, 09:57
