Thread: Boot light
    Nov 2012
    145
    Boot light
    I dont seem to have a boot light just a hole where it should be and a cable with a connectorin the hole.
    I would like to add the boot light. Can i just buy an old one off ebay? Does the replacement have to be from the same model (8p)?
    Is it as sime as conecting it to the cable and sitting it in the hole and then it will work?
    Fossie
    Rhubarb Triangle
    3,969
    Should be just that simple yes !
    Try and connect a bulb (sidelight) across the connector to make sure you have power there first. You may have to switch the ignition on and off a couple of times before it works because the control module will have switched the circuit off thinking the bulb has blown !
    Nov 2012
    145
    Thanks for the reply i have seen some on ebay but they are from 99 or 2000 year cars and mine is a 2004 are they all the same?
    Fossie
    Rhubarb Triangle
    3,969
    They're only about a tenner from Audi mate !
    Jun 2011
    Wellingborough
    1,169
    i can supply one with a nice bright LED. PM me if you want one.
    Trups
    SLOW REPLIES BETWEEN 22nd - 30th June due to been out the office, please bare with me. Thanks
    Bi Xenon Projector kits starting at £79.99 per pair.
    EM Tuning Lighting.
  1. boot light on an RS6
    By natedog in forum General Technical / How To
    Last Post: 7th October 2006, 07:44
  2. Help with the boot light
    By natedog in forum RS6 Forum
    Last Post: 6th October 2006, 11:03
  3. boot light
    By imported_migzy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th January 2006, 11:43
  4. Faulty glovebox/boot lights
    By koonl in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd April 2004, 17:20
  5. S3 Boot light switch
    By Mike.M in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st January 2004, 10:28
