Badger5Chris Nott
Results 1 to 9 of 9
    Jun 2012
    10
    Water ingress damaged BOSE amp...
    Hi all,
    My car is in at the dealer today for work to fix the creaky bucket seats. The irony is that, the day before it was due in for its road test with the tech to confirm the issue, the radio stopped working. Media, radio, bluetooth etc. all dead. Oddly though on the drive home it all of a sudden came back to life. I put it down to a dodgy wire and a pot-hole on the A6!
    Anyway, I've just received a call to say that the seat is done, however the amp has died (or is dying) due to it being wet.
    My question therefore is if this is a common fault? And if so what should I be concerned about long term?
    The car is a '61 plate, so not exactly old!
    Thanks in advance.
    Ibis White S3 Sportback, Black Edition - S-Tronic, Open Sky Roof, Bucket seats, Comfort Pack, Front and Rear PDC, Folding Mirrors, TPM System and Interior Lights Pack. Huge GRIN!!!
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Concern would be, where's the wetness coming from?
    As matter of interest where is the amp located?
    A3Kent's Avatar
    Different Gear
    May 2012
    1,065
    Got to be a warranty job? The BOSE amp is behind the boot lining on the right hand side as you look into your boot so above the driver side passenger wheel area. The BOSE sub is on the left.
    09 Audi A3 2.0 TDI 170 S-Line SB 8P3
    - Full Leather - LED DRL's - BOSE - Cruise Control - RNS-E Mk2 - AMI - Bluetooth - Folding Mirrors -
    VCDS owner - A3 Grille Install Guide
    Jun 2012
    10
    Clearly it's a concern that there's water ingress at all. But if it's simply a small leak into a boot space, that can be rectified... unless that is there are other components in the same place as the amp that might also have suffered long term damage (I'm thinking damaged but not yet presenting symptoms).
    Yes it's warranty.
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Not sure about the A3, but sometimes these areas have small ventilation vents located there. Perhaps one of those lets in water spray water?
    jamessg1962's Avatar
    Jan 2006
    Newcastle
    116
    Nathan
    Have a search for rear wiper problems. It's a common fault with the rear wiper screen wash pipe inside rear wiper.Or the pipe feeding it . Basically it starts leaking then if your lucky it may be just the wiper that needs replacing. But this leads to other problems like you have indicated if not looked at quickly.
    Some people have reported it affecting the boot central locking also .
    Hope it's a quick and cheap fix for you mate
    phil76's Avatar
    Feb 2008
    SHEFFIELD
    556
    I dont think it will be the rear washer pipe this time as that runs down the other side of the roof so shouldnt touch the passenger side,could be anything to a rear lamp seal,tailgate seal,rear quarter panel airvent just from a few guesses
    Phantom Black S3,Giac stg 1,Evoms intake,Lamin-x
    (to do list,update signature pic)
    May 2012
    West Country
    172
    Do all the bose systems have a sub in the boot?
    Mines an 09 3door with rnse, would there be one in mine?
    2009 S3 3 door. Phantom Black metallic.
    RNS-E, Tints, Piano Black inlays, Auto Lights and Wipers, Bluetooth, MFBSW,
    White Alcantara, LED numberplate lights, Black Optic Grille, Yellow Foglamps,
    K&N panelfilter, Colourmatched mirrors, S3 footplate,
    More to come....
    phil76's Avatar
    Feb 2008
    SHEFFIELD
    556
    if its got one mate it should be behind the bit of carpet on the passenger side rear under the plastic where your parcel shelf sits on
  1. B5 Bose amp pin outs for Dunk
    By AndyMac in forum In-Car Entertainment
    Last Post: 3rd March 2007, 13:03
  2. Need Bose Amp Pin outs
    By chinoy in forum In-Car Entertainment
    Last Post: 10th July 2006, 09:07
  3. Will Bose amp work in non-bose S3?
    By C_Audiboy in forum In-Car Entertainment
    Last Post: 13th May 2006, 08:48
  4. BOSE Amp
    By Naresh in forum In-Car Entertainment
    Last Post: 11th February 2005, 16:38
  5. Replacing Bose Amp for Main Speakers
    By rweerasi in forum In-Car Entertainment
    Last Post: 12th July 2004, 14:34
