Monster MotorsportVolks Autos
Results 1 to 8 of 8
    Persian's Avatar
    CEO
    Sep 2012
    186
    Unhappy Another Wet Drivers Footwell No Luck Yet
    Yet after searching the entire web for answers i still have not been able to sort my problem out.
    Basically i have a really wet drivers side footwell on my 8P1, i have tried to follow other threads on this issue to solve mine but no luck? I've check the door seals and all around the doors plus kept an eye on the coolant level but no luck.
    My gas pedal is the area where it gets wet first and the water shows? I would appreciate if anybody could list down some other areas i could check to solve my problem.
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,621
    steering column gaiter perished?
    2009 A3 SB 2.0T DSG S line
    Jun 2011
    Roslin
    105
    Quote Originally Posted by Persian View Post
    Hi mate.
    Absolute nightmare as you know...I had this on my 2007 Passat which clealy is a different model but the fault finding principles are the same. I searched the net and could not find one report of this issue on my model of car, so I had to start from scratch.
    First thinng I did was to try snd check the obvious, which is the windscreen scuttle. This can get bunged up with leaves, crap, dust etc over time. Next thing is checking your car fluids aren't leaking, clearly if they were you would be experiencing isses with other parts of the vehicle.
    If you get a mate to help you, sprinkle some talcum powder around the door seal and get a hose to water over it with the doors closed. Any leaks coming through the doors or window seals shOuld show ip.
    Next thing I did was to get the carpets pulled back and get the hose on again to see if you see any water ingress. In my case a small trickle could be seen coming from above the wheel arch area behind the dash, total nightmare! I had the screen removed to check the bonding. This showed some poor sealing with gaps, had all this removed and screen put back properly. Tested this agian but leak still there.
    Hose on again, water still coming in. To cut a long story short it was coming through the hinge body which holds the door to the car. Impossible to identify without going through the process of elimination. The fix consisted of smearing a two part bond around the hinge area! Problem solved.
    Apologies for the rant but it can be a long frustrating process. A garage would ream you out for the time taken to find it but worth persevering with it.
    Hope this helps!
    S
    Persian's Avatar
    CEO
    Sep 2012
    186
    Quote Originally Posted by SWILKO View Post
    Hi mate.
    Hope this helps!
    S
    wow! thanks for your response mate and yep now that's its raining everyday i got 2 mats ontop of one another, but as you said i have gone half way through what you said but defo would be looking further into the hinge area as no thread has mentioned that before.
    Thanks again for your response i really hope i can get it over and done with.
    Persian's Avatar
    CEO
    Sep 2012
    186
    Quote Originally Posted by Artimus View Post
    I really dont think it could be that as its more going on around the gas pedal area
    crunchie's Avatar
    Oct 2009
    Inverness
    861
    Leaks from the door speakers on all 3 of my A3's have soaked the drivers carpet.
    Mobile Photobucket
    Now:
    TTS, Leon Cupra R, MK2 Golf GTi 16v BB 3dr & MK4 Golf "GTi" 2.0 8v
    Past:
    S3 8P3
    A3 2.0T
    S3 8L REVO
    306 Rallye
    Impreza STi8
    Leon Cupra R REVO
    S3 8L REVO
    Impreza T2000
    306 Rallye
    MK3 Golf GTi 8v
    & more in between
    jamessg1962's Avatar
    Jan 2006
    Newcastle
    115
    Same thing for me Crunchie , at first i doubted it but when i removed door cards found speaker seals perished. you could see where the water was leaking.
    Persian's Avatar
    CEO
    Sep 2012
    186
    I would be checking the door speakers and see whether thats the problem or not, thanks for your responses guys appreciate it
  1. wet passenger and drivers footwells a3 1.8t - worried!
    By kam666 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th December 2012, 02:06
  2. Drivers footwell wet
    By s3joe in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th April 2012, 09:21
  3. wet drivers footwell
    By wickyianr1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th January 2011, 07:33
  4. Creak from driver footwell
    By bpascua in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th March 2008, 10:29
  5. Leaking Drivers Footwell HELP?
    By DaveS3Turbo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th July 2005, 19:55
Tags for this Thread
