PLEASE, someone help me. I'm pulling my hair out.
A little over a year ago on a summer drive to Vegas, in the extreme heat 120 degrees or more, both of my outside brake lamps went out (4 bulbs) went out with warnings in the dash all of a sudden. I checked the bulbs, they were fine, I ended up replacing the entire taillight assymbly thinking it was the chip or wiring inside the housing, none of that worked. Only my inner taillights (on trunk) light up when braking and the outer LED lights up more when I hit the brakes.
Is there a control unit somewhere that may have shorted out? Are there any other fuses that I don't know about?
I just replaced the brake switch at the brake pedal and that did nothing.
Thank you for your help!
This is what it looks like when braking, the LED should not be lighting up at all.
Here's the results:
Here's the results:
